TL-S Tranny being replaced by a CL-S tranny.
K-Fed's Stunt Double
Hey guys.
I know that I"m not a very talkative guy. But this has been plaguing me.
I really want to get a 6 spd in my TL since it is just 100 times better looking than a CL.
I was wondering, since our Auto trannies are issue-full, that if it possible to do a CL-6 SPD Tranny swap to the TL.
I already have Brembo big brakes, Tein SS coilovers, Advan 19x9.0's for my mods.
I just really want to enjoy the car I love with more power and the true feel of a sports car.
Is it possible? I'm willing to pay well if it is possible to do, can you guys please give me some links? I couldn't find some proper links with the keywords I used
thx
thx
Well the thing is , I have Greddy EVO2's in my Car, and it's made for the CL-S. THe fitment is PERFECT. The tips are maybe half an inch short of lining up with the bumper, I assume that the TL and CL are mechanically ideal
318whp/289wtq @ 6psi
..........it will work to a certain degree however no one has tried this. If you do a search(not trying to be an asshole) you will see other posts such as this. Anyway, there have been a hand full of individuals who have this this swap on the 98-02 accords. I know if you check out www.v6performance.net and do a search you will see it. Good luck!
By the way, its expensive as hell and a lot of parts are needed!
Depending on a lot of things, are you using used or new parts ...how much would labor be ...maybe so, I guess 7k could be a good guess on the price but again it depends on if used or new parts are being and how much labor is going to be for the install of it.
Well, good luck! The shop that did my turbo setup on my TL previously did a 6 speed swap on a V6 accord, and from what they told me...it was a lot of work involved. I didn't go into much detail because I wasn't really interested in it. There is a guy on the v6performance.net named Aidan. I forgot what his screen name is but I'm sure he could point you in the right direction http://www.v6performance.net/forums/...ad.php?t=53194 there is a topic regarding it that I just found.
5150crx is aidan's screen name I believe on that website.
It will bolt right up. Motors are teh same and the subframe will work. Its teh wiring and parts and labor that will run you. There are a couple threads with info on it. Do a search. There is a pretty big parts list and a big unknown as far as electrical goes. The accord guys have been doing this swap, but no one here
Originally Posted by drtoth
Where can I buy that supposedly iron-clad automatic tranny that can sustain any type of power avail?
Wow.!
wtb CL6 trany!
wtb CL6 trany!
But i would first read up on the parts list
Only aftermarket transmission that has worked on the Accord V6's is the Dr. Evil transmission. Dr.evil did say they did do one 5 speed honda transmission but they couldn't tell me any other information.
Check
www.car-part.com if you are looking for used parts. They have a transmission for as cheap as 700 something used from the quick glance I just had. Your best bet would be to find a totaled CL-S 6 speed and use it as a transplant car ...just transfer the stuff from one car to the other...again, Good luck if you pursue this.
Originally Posted by blk2001tlon19s
Check
By the way, don't know where you are located droth but there was a totaled CL-S 6 speed in Virginia that had a comptech supercharger and everything so maybe you can use that because I'm guessing it had rear damage if they are selling the engine/transmission but I could be wrong cause I didn't go to look at it.
Just go on that website, do a search for 2003 CL-S engine. You will see it, the one one listed with a supercharger. To my knowledge, they have the car there. I never called or anything.
the hand brake is in the center consol on the CL where we have a foot brake.... u'd have to install a clutch, new computer i guess since there won't be one controlling the auto tranny, and who knows what else....
ChairmanMaoSaysRTFM
bottom line: *anything* can be done with time and money.
my understanding from previous posts is that it has been done but there was alot of fabrication work needed. it's not a straightforward swap. it would also be expensive, considering the amount of parts and labor (not to mention car downtime) that would be needed.
personally, and this is just my opinion, i think you would be better off saving your money and getting a dr. evil, VR or level10 tranny upgrade. it's no guarantee that it won't fail but you're better off than you would be with OEM. don't go to a joe schmoe tranny shop and get it rebuilt though. other members (namely Optiq) have done this with unfortunate results. start shopping around and find a reputable shop for yourself.
the people i have talked to about the 6MT said that it was a "soft" transmission and would tend spin alot of tire under high-power applications. true, it's still a manual, but it might not necessarily be worth the effort. in the end it's your money and your dreams. if you want the 6MT then go for it!
SSTS
SSTS
hey i have an 02tls and awhile ago i posted i was going to do the swap with the 6spd i have an uncle in virgina that had a totaled cls that had a perfectly good front clip, even though i could of had all the parts the time involved and a small chance it wouldnt work out right wasnt worth it to cut up my perfectly good tl. ALso if i rememer correctly the cl axle is a bit longer then the tl therefore require frame alteration. might wanna look into that a bit more then i did. also your gonna have to fab a new clutch pedal mount and change out the center console. But if you do go through with it ywith success you bettter give me detailed instructions cause i want it done to my car!
SSTS
SSTS
Kris is right...especially if you are doing the work yourself, it will come out cheaper...at least it is proven that the manual will last since allmotor, thinjim and bluecl6 had no problems other than a slipping clutch with their turbos.
3k for parts is not bad. I am just after the transmission though.
Also, If it's like 2k for the tranny plus 2k for install I"m up for it. Like I said I could be a great forfactor for many TL's and also, it's something i want to show my kids I did to my first car.
Please advise.
thanks
Please advise.
thanks
Received 2,329 Likes
$3,000 sounds about right.
keep in mind you'll have to deal with wiring/ECU, pedal, linkage, center console.. the list goes on. Fortunately you can take a look at the CL compare the locations to your TL and go from there.
Please advise.
thanks
Please advise.
thanks
Also if you dont have a type-s that complicates things more since the only way the car and its ecu came was with the type-s.(thats why i was going to do the engine swap at the same time, to simplify things)
HeloDown
09-08-2015 06:51 PM
