TL-S Fogs: Can they be changed to Yello?
Old 03-18-2001 | 02:41 AM
JTang's Avatar
Question TL-S Fogs: Can they be changed to Yello?
I now have my TL-S. I do notice that the xenon lights clash a bit with the yellowish lights of the fogs...can I change the fogs to be a yellow like the IS300 or PIAAs? Any ideas?
Old 03-18-2001 | 07:19 AM
bobatimez's Avatar
Post
the fogs one the tl and cl are soooooooooooooooooooooooooooooooooooooooo nasty. they're only good for making the xenon's look better. NASTY-CHEAP-BURNING DIM THINGS. u could probably change the bulb.
Some Said, "TL Type S," Soon They Will Say, "Wannabe TL-S." Laguna METALLIC, Navi, Side Cuts, Tint All Around, Interior Footwell Lighting, Eibach ProKit, PIAA 1700x Fogs custom cut into side holes, Inspire Tails, 17" Type-S Rims with 215/45/17 Bridgestone Potenza RE730's, Visor, Wood Shifter, Comptech Sways making me ride on rails...
http://albums.photopoint.com/j/Album...026&Auth=false
Old 03-18-2001 | 07:30 PM
Lightbulb
Yes you can certainly change bulbs! If you check the owner's manual (unless you wanna pop the hood or unscrew te bottom of the bumper to check bulb size), the high beam (the middle round ones) use HB3, which is the OEM 60W 9005, and the fogs are HB4, 51W 9006, these two bulbs are very widely available in aftermkt, blue, yellow, super white, you name it.... oh yea, I like to drive with the fog lghts on, cuz don't you feel the field of view at nite is so wide with the fogs on?
mrkingstonvi
02-22-2016 02:53 PM
mc1114
10-08-2015 02:26 AM
datadr
09-12-2015 10:12 PM
Aleax
09-11-2015 12:31 PM
JnC
09-11-2015 07:06 AM
Quick Reply: TL-S Fogs: Can they be changed to Yello?
