TL Radiator and Condenser Fan Questions when AC on......
A/C ON:
Both Fans on @25%-50% switching On and Off depending on Outside Temp, Full ON if Outside temp is too high.
TL uses both fans at the same time always.
Thank you that is exactly what I needed to hear. I never really paid much attention to the fans but ever since the overheating issue Ive been a bit paranoid now! I did notice that at one point both fans were on at a higher rpm and turned off and from there it just kicked on and off at a lower speed. Makes sense from what you are stating no point to have it on at all times at it would probably cool the car down more than it should! Both fans do kick on at all times!
