TL-P 6sd?
TL-P 6sd?
Is a 6spd conversion possible with the tl-p motor, and have everything running right like no limp mode?
I've been reading through hours of threads but still not sure.
Any help is appreciated.
Yes. You will need the richie module.
There are many threads about 6spd swaps, and many pages to read through.
I just wanted to know if it was possible without swapping the motor and keeping my tl-p engine to keep the overall price cheaper.
I want the swap mostly for the reliability of the trans.
I understand I need rv6's module, but unsure if i will need a cl-s pcm?
Also, how do i even contact rv6?
alexh1266 (07-28-2011)
Indeed but I don't want to go through the hassle of pulling out the motor and going through all the wiring.
As well as I won't be doing this project alone, and will end up paying someone to help me out.
I mean the motor doesn't need to get yanked out to do just a 6spd trans right? At least thats what I thought?
You don't needed yanked out the motor to do the swap. Just remember to change of the rear auto mount to 6speed bracket an mount when you remove tranny.
BTW:
My 6speed thread only had 2 pages
https://acurazine.com/forums/2g-tl-1999-2003-98/finally-doing-6speed-swap-763216/
BTW:
https://acurazine.com/forums/showthread.php?t=763216
BTW:
Also how do I get a hold of Richie for the harness/module?
Or where do I order it from online?
The only different in my is you can see in diagram of what your buying an where i got parts from. Sometime just get parts# can still be confusing...
Also in googles search " V6 obsession" an you find Richie thread. The 1st thread on TOP.
Checking for parts now and everything seems reasonably priced except for a few things.
Cup holder - $91.56 I will def try to find a used or junkyard one. That price is ridiculous.
Clutch pedal bracket - $317.87 WOW! This shit is that expensive. Can this be interchanged with something else. Or what else can I use. I will def try to find a junkyard one of these.
And the shift boot and shift knob combo comes out to - $274.47 that hurts a little
does anyone know the part # for the silver trim around the shift boot that tells you the gear locations?? That would be nice to have as well.
And the starter is $408.74. This would be nice to have new for peace of mind, but how well will a used one hold up. I got the phrase "do it right the 1st time" implanted in my mind.
Parts List:
ok here is my parts list so far. please let me know if im missing anything.
03 CLs-6 speed manual trans
03 CLs-6 Flywheel 22105-PGE-305
03 CLs-6 Clutch Assembly 22105-PGE-305
03 CLs-6 Flywheel bolts (Qty 8) 90011-PGE-000
03 CLs-6 Shifter and cables. 54100-S3M-A01, 54310-S3M-A01
03 CLs-6 Hydraulic Clutch lines. 46960-S3M-A01, & 46970-S3M-A01
03 CLs-6 Trans mounts (2 of them) 50806-S3M-A03, 50805-S3M-A03
03 CLs-6 Cup Holder 77230-S3M-A01ZA
03 CLs-6 Parking brake 47105-S3M-A04ZA
Spring 47537-671-670, Nut 47522-594-000, Equalizer pin 47365-538-000, Equalizer 47360-SB2-000
BRAKE PEDAL ASSY 46600-S3M-A51
CLUTCH PEDAL 46910-S3M-A01
CLUTCH PEDAL BRACKET 46990-S84-A01
MASTER CYLINDER ASSY 46922-S3M-A01
Clutch Fluid Tank 46965-S5A-013
Clutch Hose 46961-S3M-A02
Shift Boot 83414-S3M-A01ZA
Shift Knob 54102-SL0-023ZB
03 CLs-6 Rear Engine mount and bracket 50810-S3M-A01, 50827-S3M-A00, BOLT (m12X25) 90166-S3M-A00
03 CLs-6 Starter 31200-PGE-A11
Questions:
Will it make sense to replace the gauges with type s gauges if im keeping the stock tl-p motor?
Will richie's module make everything run perfectly? What problems can i expect. i dont want CELs or anything because i must pass emissions in California.
will i need this part: IMRC 37850-PGE-A01 if im keeping the stock tl-p motor?
Thanks in advance.
Questions:
Thanks in advance.
The point of the module is for the ECU and not having to rewire the whole car, not the gauges
Questions:
Thanks in advance.
Questions:
Thanks in advance.
If you read thru hours of posts you would know you can use different clutch pedals. Look for an accord clutch and brake pedal set.
Do a little search on the module. Read up on it. Its purpose is to make the car run WITHOUT having it throw any codes. Its main purpose is to trick the auto ECU into thinking the auto trans is still there so it soesnt go into limp mode
NO, you dont need the IMRC. That is ONLY for the type-s motor.
Thanks Kris.
i dont mind paying for new pedals themselves, I was just shocked that the clutch bracket was so expensive.
Other than that. Are the gauges plug n play? Remove old gauges and plug in new gauges to existing wires/setup?
If it's that simple then that would be the last thing i would be doing.
Wow, read through all 97 pages yesterday of the "6 Speed obsession" thread. Most people did a J32A2 swap and the module worked.
I'm keeping the J32A1 engine and 2000 stock ECU.
According to the thread its confirmed to work with the 4AT ecu, but what about the 5AT TL ecu? Anyone else done the same thing i plan on doing?
I'm ready to order parts guys, just gathering all the info possible so i dont run into any road blocks.
SCEPTRE
07-02-2005 10:54 AM
ZeroPSI
03-14-2005 10:42 PM
