Tl keeps dying while driving??
99 NBP tl
Check to see if the recall for your ignition switch has been performed. It is a common issue with 99's. There are many threads about it in the problems and fixes subforum
ignition switch back- 50 bucks at parts stores if the recall has already been done- they only replace it once!
easy DIY if recall done already- see that section for info
if the dash lights come on and it stalls then comes back to life, maybe more on corners,,
ck your key ring- more than a few is bad for it too
register with acura as a new owner 1-800-382-2238x5
ask if any open recalls or things you need to know about- any warranty work ever done?
the egr port recall done?-ign switch done?
