TL Brake TSB
TL Brake TSB
I have been looking for about an hour for the TL Brake TSB. I need to show it to the service manager at Continental Acura in IL. He said they will only machine them down, and I say NO, replace them. I have a 2000 3.2TL with bad brake vibration.
If he is simply going to machine them, I may tell him to forget it and I will get some new slotted ones and do it myself.
If you want something done right, you gotta do it yourself!
Re: TL Brake TSB
What they will first do is measure the discs. If they are below the minimum requirement for thickness, then they will swap the rotors for a new pair. If there is still room for them to be machined, then they will go ahead and do that.
The TSB that states this is here:
http://www.**********.com/tsb/2001/b01-017.pdf
good luck with that.
TSB BRakes
Thanks all. I searched on Google for B01-017.pdf and it came right up with a listing of many Acura TSB's. Check it our at
Thanks again....
Thanks again....
Re: TSB BRakes
Thanks again....
Thanks again....
you have to replace the ( and 0 with c and o
GWEEDOspeedo
01-15-2016 10:39 PM
