tires+rims+mount=DIY?
hey guys, just got some new rims and tires, just wondering if there's a way i can put them two together, and put them on the car by myself?? or leave it to the prof.?
In my younger dsays i used to work at Sears tire & auto. It is not a DIY unless you have the equipment as eyesnake02 stated. But one thing i do suggest is when you go to get it done, make sure you request that they place the balancing weights on the inside of the rim, where you cant see them, or use the ones that stick on the inner part of the rim. I dont recomend using the stick on ones since they can pop off and you will have to get them balanced again! Hope this helps!
Initial D
I find www.tirerack.com has good users' review on tire shops. Just enter your zip code and you should be able to find a good one in your area. By reading feedbacks at tirerack, I found a shop that actually uses torque wrench to tighten lugs and only charges $16 per tire that includes mounting, balancing, and disposal.
oh, when you get new rims/ tires, do you need to do anything else other than mount and balance them? like alignment(i dunno what this is, but sounds wheel related) or anything like that??
SUPRMN84
10-07-2015 09:46 PM
pistacio
09-26-2015 09:45 AM
