Tires
Old Oct 27, 2016 | 11:09 AM
mgnk3u's Avatar
6th Gear
Tires
I currently have the stock tires on my 2003 Acura TL Type-S(P215/50R17). A friend of mine has 4 P215/55R17 and I was wondering what a difference they would make or if I could even use them?
Old Oct 27, 2016 | 11:23 AM
the sidewall or profile height is a little taller than stock. it has a variance of over 3% which is too much and your spedometer will be off.
acurazine has a tire calculator that you can use to compare tire specs.
my favorite tire calculator is from 1010 tires tho which can be found here
http://www.1010tires.com/Tools/Tire-...0R17/215-55R17
Old Oct 27, 2016 | 01:45 PM
Skirmich's Avatar
To OP you can use any tire combo you want, its the difference in gearing what will affect the outcome being a faster tire or a slower tire.
Smaller circumference tires will give you slightly better acceleration while Larger tires will give you higher theoretical Top Speed.
So staying between the stock circumference might be a good idea.
Clint08TLNAV
34
Oct 12, 2016 10:32 PM
Syms
Aug 30, 2016 08:07 AM
drewb71
Aug 29, 2016 08:05 AM
njresendez
Jul 18, 2016 08:46 AM
mtiaz
Jan 20, 2016 10:54 AM
