tire size/exhaust ?
Old Sep 4, 2003 | 02:47 PM
looney010's Avatar
Veritas vos Liberabit
tire size/exhaust ?
quick question, i want 19x7.5" wheels and i know that the optimal tire size is 225-35-19. however being that they are practically rubber bands and that i am only going to do a H&R OE drop, i figure i might be able to fit 225-40-19 with no rubbing issues; is this possible?
another question, has anyone used hayame exhaust/muffler products? i was looking to get 2 Hayame EXT mufflers for my TL cuz i like the dual tip look and i think that setup would look pretty good; if anyone has any input, i would appreciate it, thank you!!
Old Sep 4, 2003 | 03:42 PM
goldendragon576's Avatar
TL-S driver
I don't know much about the exhaust but for the tires it all depends on the offset of the rims. If you put +50's you shouldn't have a problem with either tire, but if you have anything less you might have to make some minor adjustments to the fender. I have 225/45/18's with a +45 offset and I had to cut the lip and roll the fenders a little bit. The closer to +50 the less chance of problems you'll have.
Old Sep 4, 2003 | 03:50 PM
looney010's Avatar
well since the rims are 7.5" width, i was gonna get +45 cuz i heard that will be ok... so 19x7.5" with +45 and 225-40-19 tires will rub? if not i guess i'll have to go with the 225-35's... just wanted a slightly thicker tire...
Old Sep 4, 2003 | 04:18 PM
r10apple's Avatar
lover and fighter
Slightly thicker = 235/35/19, which would be the optimum size...You still may need to roll your fenders with 19's and a drop...Just keep that in mind...
Old Sep 4, 2003 | 04:33 PM
looney010's Avatar
oh, i meant thicker profile, hence the 40...
anyone know anything about hayame (sound, rep?)
Old Sep 5, 2003 | 03:15 PM
looney010's Avatar
nobody?
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
DidiBob
Jan 4, 2016 12:41 PM
Robospinner
22
Sep 24, 2015 08:47 AM
CostcoFanAUS
Sep 18, 2015 06:05 AM
fallacy
Sep 4, 2015 10:15 AM
