Tire PSI
Its more of a user/car/tire adjustment. Most are running different tires/brands than stock, and each tire is a little different. Ill go as high as 38 on my stock sized snow tires. with my summer tires i run anywhere in the neighborhood of 36-42 depending on if im going to be doing a lot of hwy driving or just normal around town. Play around with them and see what you like.
I just do 36>38 psi all around. Seems to be a good compromise, IMO.
Registered Nonmember
My starting point is 80% of max cold psi. So in your case I'd start around 35 psi.
My current tires have a max pressure of 51. I usually keep it above 38 and up to 42, but above 40 the ride gets a bit rough.
^ Tire exploding? Once the steel belts separate can create a hole enough for the air to burst add that in a vehicle in motion and you can have a pretty big accident.
I had been running 32 PSI all around on my Goodyears, but in preparation for the temperature dropping and a significant number of highway miles, I bumped my pressures to 38 all around. I was very surprised to find a noticeable improvement in car feel when aggressively cornering, plus the tires don't squeal anymore at the same speeds (or even slightly higher speeds) when cornering.
I didn't realize the variations of PSI folks run
I usually run the recommendation or a couple PSI above... Anywhere from 32-34 PSI. I'm going to try a little more pressure around 36 and see if the ride feels any better.
NBP_BALLER
09-23-2015 08:18 PM
CostcoFanAUS
09-18-2015 06:05 AM
