Tire Pressure confusion
Happy with my STi!
Ok guys, this is the deal. I bought a tire pressure reader (or whatever its called) at Autozone. The one that is about 30cm long (not the crappy cheap ass one). So when I use the one I bought I get reading of less than 30psi, however, when I use the tire pressure reader that is connected with the air pressure from the gas station, it reads less than 35psi. With this result, the tires from the front look a little low in air, so I decided that the one I owe was giving me the right reading. What the hell? What is wrong?
Happy with my STi!
Originally Posted by edgalang
Is it a digital tire reader? If so...trust the one that you bought.
2400 Watts in a TL...Why?
1 Post
If it was recently purchased I would say go with your tire reader. The gas station ones are always off and never serviced to check accuracy (it's a free product, what's the point, according to the big gas companies). I know of a few guys that keep one in their glove box because of problems with over filling or under filling by other drivers of their cars (mother in one case, way over filled, and a girlfriend overfilled the tire another time). I am going to pick up a digi one soon I think there only 15 bucks or so.
Purchased: April 28, 2001
Originally Posted by thsiao
I don't think its a digital reader... just a regular reader, were a stick pops out.
Why not get a digital reader? You can get them for under $10 and they are a lot easier to read consistently.
You can get them online...Cheap Digital Tire Guage
Or your local Radio Shack...or pretty much anywhere. Personally, I'd never go back to an analog guage reader.
Happy with my STi!
Here's a better idea. It's only $20
Or...you can get something like this...so you wouldn't have to go to a gas station. Besides...you want to measure tire pressure before you drive it anyways.
12 Volt, 250 PSI Inflator with Digital Gauge
Happy with my STi!
Since you live in L.A., there must be a Target near you. I got my digital pressure monitor from there. It's called AcuPressure (sp) or something like that and it was around $12.
If you have a Costco membership I also saw the same one being sold there which also included a mini key-chain digital tire pressure monitor.
Ignore the tire pressure gauge at the gas station; they are never that accurate do to the abuse they take from other customers. The tire gauge you purchased is most likely just fine. It’s best to check the tire pressures before driving, however if you have to drive a short distance to a gas station the change in pressure will be minimal - so don't worry about it.
FWIW, I bought one of these like 10 years ago. Still works awesome, has always been accurate.
http://store.summitracing.com/defaul...=tire+pressure
[QUOTE=ronvanr]Ignore the tire pressure gauge at the gas station; they are never that accurate do to the abuse they take from other customers.QUOTE]
I stopped at a mobil the other day to get air and they had this new digital air pump. After you put your $.50 in, you punch in the desired pressure. The pump will put in or take whatever it needs to get to the desired pressure. I thought that was pretty cool. I seemed to work well too.
I use an Accu-tire digital that measure to 0.5 PSI, and make sure I read it 3 times. Read about it in Consumer's mag a few years ago as one of the more accurate and reliable gauges. Pep boys at around $15 to $18...
mugen_kid
11-13-2015 10:38 PM
NBP_BALLER
09-23-2015 08:18 PM
HeloDown
09-08-2015 06:51 PM
