Tips for first do-it-yourself oil change
Well, the car's got about 3000 miles on it and it's probably getting close to that time when I want to use a synthetic. Any tips on preparing for this do-it-yourself job? I'm gonna probably use a Synthetic 5-30 oil (not sure which brand just yet), and a good filter (either Mobil1 or PureOne). I did a search but can't seem to find anything really on the basics of oil changing for our type of car. Thanks all!
Danny
Danny
To change the oil and oil filter is quite easy. I park my car on level ground and turn the steering wheel to the right until it turn no more. The drain plug and the filter then are both accessible from the right front wheel area. I don't even have to lift the vehicle. I use Mobil 1 0w-30.
ok . drive the car up a ramp and pop the hood. Than look for the oil cap and take that off. go under the car and look for a nut in the oil pan. the correct size of that nut is ?mm (forgot)(in the teens) ne way, than put a bucket under the oil pan and release the nut. and next to the pan should be the oil filter, turn that until it loosens up and oil is gonna pour out.
Take the new oil filer and use some oil around the rubber seal. Screw that on and put the nut back in the oil pan. After pour the oil in the oil filer hole.
personally i wouldnt use synthetic beacuase it fu use that, than u would have to put synthetic in the car for the rest of its life. if u switch back to regular oil, ur gonna blow the engine.
Cool but I seem to recall there's some kind of nut or fastener that once removed needs to replaced with a brand new one? If so, where's the easiest place to get these?
When I seal the new oil filter, do I use the OLD oil or the new? What if I'm using the Synthetic for the first time?
I also recall that the service light will come on at some point for the first oil change ... how do I reset that, or should an authorized service center get involved at all?
Sorry for the noob questions.
Danny
Danny
I got a blown engine when switch back from Synthetic to regular oil (no not my TL - I forgot when's the last time i drive the TL)
Originally posted by roadman
Your info is way off base, synthetic oil and regular oil are indeed interchangeable, they sell it blended as well. Once you do use synthetic you will not go back once you see how well it performs.
Originally posted by planetside
What if I opt for a non-Acura filter -- would this require the crush washer?
Danny
Danny
Originally posted by Alexxx
Oh and if you want a crush washer, it's $0.25 at the dealer. Bought two of them at PAA
I went to Sierra Acura in Alhambra and the fool at the parts department wanted to charge me 90 cents for each crush washer. I was like wtf
So I walked one block down to Goudy Honda and bought a bag of ten crush washer for the V6 accord and it was only 20 cents each.
Don't get me wrong, I'm not cheap, but to charge me almost 5 times more for the same damn item is nuts. I guess they figured that since you bought an Acura instead of a Honda you might as well pay their luxury prices for the same items.
Sierra Acura
Sierra Acura
A floor jack makes it a little easier for me, I sit pretty low with the body kit, springs and tires. I use the jack to take the load off the front springs (I don't lift the tires off the ground), works fine for me.
fram makes a quick oil change plug, replace the old one with the new one (fram) when its time to chang the oil just simply unscrew the cap and screw on the hose, no oil will drain out until the hose is screwed on. it makes it nice and clean. you can get it at most parts stores and works really nice. and you can do it all without jacking up th car. with this system you dont have to replace the crush washer ever again, or get any oil on you or the ground
mada51589
05-03-2022 08:54 PM
HydrasunGQ
09-14-2015 10:14 PM
