Timing Belt -- Mileage or Age?
I have a 99 TL bought in 11/98 with 57k miles. Dealer tells me timing belt overdue (they rec. 7 years). Independent mechanic tells me that he would wait for 105k miles on timing belt -- that this is a repair where time doesn't matter, just mileage. Thoughts? (And, yes, the dealer recommends I change out the water pump at the same time.)
I wouldnt use that mechanic. At this point in its life AGE is FAR more important than mileage. Rubber gets brittle.
Wouldnt matter much, odds are if it were to fail in town you would still need a new engine. And my bet would place the city driving harder on it than the constant speed hwy driving
get a real honda mechanic~~~
...as well said many times- age before brittle or something like that
I know the results of failure- 10 years 175kmiles on a teg and shredded the belt-
goodbye engine! (wifes car before my time)
and it went in town, not on its daily 90 mile commute in the 100 degree weather..
while her idiot friend kept revving it and said- its ok,, you can make it back home!
It would be foolish to not replace the water pump with the timing belt- its next part behind the belt and will fail in another 20-50 if you dont replace now
Same with all tensioners and pullies for the belt- dont replace now and good chance they are not long for this world
2000 TL Black on Beige
110,000 mile parts report:
T-Belt - Looks perfect. Yes, the time to change it is way, way before you need it.
Water pump - A little clicky play, evidently within bearings, if one wiggles the pulley.
Tensioner - has a little oil and black crud around piston. Could be original grease and flecks of rubber from t-belt wear.
Pulleys - Seems to have no issues. Amazing one can build sealed bearing to withstand the heat and 100K miles.
P.S & AC belts - Cracked, worn.
Conclusion - I'm glad everything was changed out. An extra $210 well spent.
When I have a garage, and a non-daily-driver, I'll do the service myself.
you have to flip the tbelt inside out, bend it backwards at the teeth and look for any cracks.
Chances are if the outer belts were dry and done- so was the tbelt- just not as obvious
a little oil from the tensioner, a little play in water pump...gee you could have gone another 50 miles before serious engine damage occured~
front rotors of OE quality or better can be found for cheap at autozone or kragen/oreillys
Next time tbelt DIY? how long will it take you to put on another 100,000 miles!?!
trying to compete with fsttyms1? lol
I meant as an inspection procedure after replacement--since the poster said it appeared good I wanted others to know how to inspect the timing belt..and why a techs best guess that its ok from an outside peek--are worthless
once you have it off dont even consider putting it back on!!!
Yes, when you flip the t-belt upside out, and squeeze the belt, the little alligator scale cracks are visible.
I'll do 100K in three years, mostly highway. And hopefully, so will the transmission.
Honda resurfaced the rotors, as they had over 2mm left on them. With new pads, it added $160 to my t-belt bill.
They have a machine that resurfaces the rotors without removal, and claim this is the right way.
Never heard of, or saw such a machine, however.
I'll try this out, and if they go shaky within 35,000 miles, then I'll install EBC UPR7087 rotors.
OEM pads were recommended with these rotors. Yes?
If you get the EBC rotors, get the EBC pads. They are far better than the OEM pad.
I prefer teh Green Stuff pads, but those arent bad
I was JUST about to ask/post the same question...
(i dont mean to high-jack the thread either...) but why post twice..
My TL is a '02 with 40,000 miles on it (9 years on the road -june '01)
This car doesnt see winter and on average 5000 miles a season.
I initial feeling is that the T-belt should be good for a while longer.. but how long..?? or maybe not.
Thoughts...
J
Thoughts...
J
Thoughts...
J
Thoughts...
J
Age is far more destructive than mileage to rubber.
Unless I get a divorce and my car becomes my main transportation, I will only put another 40k for the next 9 years again...
There are a few TL owners that have mentioned than after 100k the belt was in decent shape.
The jury is still out....
J
I agree that age is a factor, as you mention above 'replace and get another 75-100k'.. there lies my dilemma.. it ONLY has 40k on it, after 9 years...
J
J
S E L L
I recently had mine replaced (2000 TL, 103K miles) and the belt was visibly worn, more so on the back side than the tooth side. I had everything changed, belt, pump, idler & tensioner pulleys, hydraulic tensioner assembly, and drive belts. My water pump had signs of a slow leak, not enough to leave puddles but enough to make me wonder why I had to refill my coolant bottle every so often. The hydraulic tensioner also had a small leak so I sure as hell wasn't putting that back in. I had to wait until Monday to get it at the dealer because we did the work Sunday and nobody else carries it. The idler & tensioner pulleys actually felt pretty good. The bearings were still spinning smooth and didn't feel worn at all. They felt very comparable to the new ones but since I had bought the kit (Gates timing kit BTW), I went ahead and replaced them anyway. The drive belts were also Gates and the water pump was a Beck/Arnley (re-boxed OEM supplier parts).
BlkTxAcuraTypeS
10-18-2015 08:05 PM
asahrts
09-04-2015 05:55 PM
