Timing belt hydraulic tensioner. Replace? or not?
Hi All,
Just getting ready to replace the timing belt on my 02 TL-S. So far I'm planning on replacing the following:
- Timing belt
- Water pump and Gasket
- Idler Pulley
- Tensioner Pulley
Possibly replacing:
- Camshaft seals.
- Crank seal
- Hydraulic tensioner
My main question is whether the hydraulic tensioner is worth replacing? The service manual just shows re-using the existing one after compressing it with a shop press. If it's worthwhile I'll replace it, but $160 will buy a lot of beer if that part never fails. The side question is wether the crank and camshaft seals should be replaced while I'm there. I had the crank seal replaced 100k age when the timing belt was done.
Thanks in advance!
- Timing belt
- Idler Pulley
- Tensioner Pulley
Possibly replacing:
- Camshaft seals.
- Crank seal
Thanks in advance!
Thanks in advance!
Thanks in advance!
Rockauto has the Aisin for $66.79 before shipping.
You'll still have roughly $90 for beer and peace of mind.
I'd only change the cam & crank seals if they showed signs of leaking, YMMV.
The following 2 users liked this post by zeta:
Jon M (03-03-2023),
whitetiger5 (03-04-2023)
johnnyblaz3
09-16-2008 12:23 PM
