Timing belt
Timing belt
So, my 2002 TL-S has 92,000 miles, and, per the owners manual, the timing belt is due at 105,000 (If I recall correctly). Since I have taken so long in years to reach this mileage, should I just go ahead and replace the timing belt now? Could be timing belt be getting weak just from age, and not necessarily mileage?
Yes, age is more of a factor than mileage. I would look into getting it replaced.
as well as looking to pay an arm and a leg
but seriously, try & find a local shop that specializes in honda/acura's, it'll be about 200-300$ cheaper than your dealership
you won't get a loaner car or that nifty lil free car wash of course
I wonder what the book says in terms of hours for this job?
6-8 hours per book
have the timing belt pullies and tensioners replaced, anything that moves wears out
Change all the fluids, brake, ps fluids
Thermostat not a bad idea
Valve adjustment
See the many threads on this subject for complete parts list and prices~
Beware low quotes to get you in the door, then price jumps
Get a real estimate of actual parts being used, a good shop will be able to help you
Valve adjustment
under normal driving conditions- 7 years or 105k miles is the book spec
water pump is a given with timing belt, its the very last thing and right behind the belt!
some late 02 and some 03 get a recall timing belt pulley- ck your vin with acura 1-800-382-2238x5
you can pay extra for water pump and save several hundred as acura provides a new timing belt and its pulley and all its labor
I called an independent shop that I trust. Was told that for $1,100, he would install a timing belt "kit" that consists of the belt, water pump, rollers?, cam and crank seals, and the tensioner. Something about these being Asin parts, not Acura OEM parts. Says I could opt for OEM parts too. Cost breakdown was about 50% parts and 50% labor.
Gonna call the dealer to compare.
the only part that ziners seem to think is really good from acura is the water pump and t belt- it lasted this long so hopefully its replacement will too
If its a well known aftermarket brand part the shop has used many times and cars are still running- go for it
those cam seals are rare to need- get the valve adjustment quote too, there is some co-related parts removal so you save over having just it done
Get spark plug prices too
OK i dunno why but my dealer Honda Optima in El Centro CA. quote me for: All parts (Belts [Timing, PS], Hydr Tensioner, Idler) and seals (Cams and Crank) (OEM FTW!) and Labor for 740$ + tax how does it sound it is OK to go with it? they have it done in 2 days 1 for parts shipping and 1 for install.
low prices always get jacked up once the car is taken apart and you have no choice
I was a service writer- trust me~
I dont see water pump on that list--you replace that now because its important,, and right behind the timing belt!
add xxx dollars Sir
And its due for spark plugs if you have not done them yet- big price jump to do that
add xxx dollars Sir
BlkTxAcuraTypeS
10-18-2015 08:05 PM
asahrts
09-04-2015 05:55 PM
