For those with RichieV6 Modules
Hey guys, I know it's been a while, I've been busy with school lately. My car has been running and doing great, but I still cannot figure out why it will not start without the automatic transmission range switch. I haven't been worrying about it lately (KY does not have inspections) but I graduate in May and might have to take a job out of state that might require inspections. With the auto trans range switch plugged in, I get a CEL and I cannot get reverse lights to work.
For those with the modules, does the D5 light come on before you start it? I have followed the wiring diagram to perfectly. The clutch safety switch is also wired correctly and I can even wire the two white wires together. I cannot figure out what the hell is going on. I really don't want to have to get rid of this car!
http://www.youtube.com/watch?v=ZxW9W...ature=youtu.be
Wiring diagram
Wiring diagram
Mr.Helpful Diagram
I dont have a richesv6 module but do you have the service manual ? It shows what the range sensor does in order to let the engine start.
Friesm2000 have been working on it and I was able to disconnect the brown wire (ATPNP) from the module and to the chassis (ground) and the car was able to start. It appears the module is not getting power as I've touched my multimeter on the connections (primarily IGP) on the module and am not getting any readings. I'm going to check my connections on B1 and B2 tomorrow and see if they are bad joints or maybe I tapped into the wrong wires.
SUPRMN84
10-07-2015 09:46 PM
HeloDown
09-08-2015 06:51 PM
