For those with Konig rims
Old 02-01-2001 | 11:57 AM
Guest
Guest
Posts: n/a
Question For those with Konig rims
I am about to order the 19'' Konig Tantrums with Nitto 555 235-35-19. I like to drive fast, who doesn't, but I am worried about bending or worping the rim....usually i am 50-60 main roads and 85-110 on the expressway. Do you think this will be an issue? Has anyone had any bad experiences with Konig and bending? I want to order them by the end of the week and want to make sure they are the ones for me
thanks for the advice
Old 02-01-2001 | 07:44 PM
TLon19s's Avatar
Post
Thats the exact setup that I have for bout year and a half with no problems...nock on wood...
Old 02-01-2001 | 08:28 PM
Shoofin's Avatar
Post
Arn, it matches up very closely...
Specification Sidewall Radius Diameter Circumference Revolutions Difference
205/60-16----4.8 in----12.8 in----25.7 in----80.7 in----785 / mile-- 0.0%
235/35-19----3.2 in----12.7 in----25.5 in----80.0 in----792 / mile-- -0.8%
Ed
Acura-TL.com - Forum Moderator
'99 TL Satin Silver/Ebony, Non/Nav, Comptech lowered, Comptech Air Filter Element, Inspire Tails, AEM Brake Pads all around, Comptech Axle Back Exhaust, "Guy Smiley" doll on the dash as my Co-driver...
Pics of my TL
Pics of my Miata! Wadya think?
Old 02-01-2001 | 09:23 PM
adamyankee's Avatar
Cool
Originally posted by Arn2000tl
Is there any tool online to put in the dimensions of you old wheels/tires and tells you what specs u need to match the same tire diameter when u purchase bigger rims with a lower porifle tire? I don't have the time to do the math when playing with tire sizes...
Try this. I think it will help a lot.
http://www.miata.net/garage/tirecalc.html
Old 02-01-2001 | 09:35 PM
Guest
Guest
Posts: n/a
Post
My friend has Konig DTM's on a del sol. He cracked one by hitting a pothole on the high way. It cracked as in, it was cracked through. It separated. But that was probably one of those one time freak accidents.
Old 02-01-2001 | 09:43 PM
Shoofin's Avatar
Post
Or this....
http://www.powerdog.com/tiresize.cgi
Pics of my TL
Old 02-02-2001 | 12:07 AM
StreetEffectz's Avatar
Post
Shouldn't be an issue. My friend has tantrums for a year now and drives everywhere...no problems.
Old 02-02-2001 | 12:20 AM
adamyankee's Avatar
Post
What time do you drive that fast on the LIE. Either you work in Suffolk or you are obviously not driving between 7:30 a.m and 8:30 p.m
Old 02-02-2001 | 12:21 AM
Guest
Guest
Posts: n/a
Post
as far as the ratio goes, i should be ok with those dimensions? i don't want the speedo messed up or odometer clocking more miles then i already have =)
Old 02-02-2001 | 12:22 AM
Guest
Guest
Posts: n/a
Post
Correct...I work in suffolk
Old 02-02-2001 | 12:26 AM
fred3113's Avatar
Cool
hey there,
i had a set of konig caffeines (chrome) and they were 18's by 7.5 and they did not hold up to well, i only had them on for one summer before having to get rid of them, it seemed like they were to soft, but maybe that was just my experience, good luck with them.
2000 TL, Satin Silver, Burlwood shifter, Fog light ports, front air dam and mud gaurds custom painted to match car! 18" Alba Blaze with 235/40ZR18 Toyo Proxes F4
Old 02-02-2001 | 09:42 AM
Guest
Guest
Posts: n/a
Question
Anyone have a pic of a TL with these rims, but without having the car lowered? I don't have the skirts all around and didn't plan on dropping the car, but want to see how it will look because that might be a requirement....i don't want huge gaps in the wheel well
Old 02-02-2001 | 10:03 AM
NSXNEXT's Avatar
Post
It'll look like a 4x4 without a drop. There will be HUGE gaps in the wheel well without dropping.
1999 Satin Silver Metallic 3.2 TL w/o Navigation
  • Factory underbody kit and spoiler
  • Burlwood shift knob
  • Trunk tray
  • 20% tint
  • Ractive intake
  • Clifford Intelliguard 9000 alarm
  • Alpine 6 disk CD changer
  • Comptech springs, sways, exhaust, and headers
Old 02-02-2001 | 07:43 PM
Guest
Guest
Posts: n/a
Post
anyone know how much the stock rims for a '00 TL weigh without tire?
Old 02-02-2001 | 08:46 PM
Rice1304's Avatar
Post
nope, i've heard many a story about konigs getting cracked and damaged. You get what you pay for and if you buy the insanely crappy konig cast rims then you should be prepared for the worst.
Old 02-03-2001 | 12:11 AM
Rice1304's Avatar
Post
~ 22 lbs and most konigs weigh more. Not to mention you're downgrading from stock enkeis to konigs.
Old 02-03-2001 | 09:58 AM
Guest
Guest
Posts: n/a
Post
the konig tantrums run 26lbs for 19''s so thats not a big diff. The reason I want those rims (in regard to your previous post) is because I like that look. Having the spokes go all the way to the end wihout having any rivets or anything looks sharp, IMHO
Old 02-03-2001 | 02:22 PM
Rice1304's Avatar
Post
I can't believe that you still want these rims after two people (ONLY on this board) already said that they got konig rims damaged. Konigs are regarded by high class car owners as lowly, for civics, and for ignorant people who are just plain cheap in the world of aftermarket parts. The tantrums (along with a handfull of other immitations) are a cheap knockoff of the AVS model 7s which is forged (much lighter and stronger than cast). Don't blame me if you get the tantrums and a week later you see a million civics riding on the same rims.
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by Rice1304 on February 03, 2001 @ ]</font>
Old 02-03-2001 | 02:24 PM
Rice1304's Avatar
Post
oh yah and believe me, 4 lbs and 19 inches will make a noticeable difference in hp to the wheels.
Old 02-03-2001 | 03:52 PM
Guest
Guest
Posts: n/a
Post
Do you have a link for those rims...I'll take a look at them. i don't care if are cars are ridding around with them, i like the way they look.
Old 02-03-2001 | 05:19 PM
Rice1304's Avatar
Post
http://www.checkerflag.co.jp/avs7.htm
Old 02-03-2001 | 06:49 PM
Shoofin's Avatar
Post
Hey rice, go easy on him....Personal preference, man! I like the rims too, but I know they are heavier and not as strong as others, thats why I'm not getting them..
Ed
Pics of my TL
Old 02-03-2001 | 07:56 PM
Guest
Guest
Posts: n/a
Post
I LIKE those..are they only available from overseas? How much do then run? It does look like Konig ripped off that design...plus they come chrome which is always nice
Old 02-03-2001 | 08:27 PM
Rice1304's Avatar
Post
Ed
just some friendly advice . oh yah btw the advan avs model 7s are imported and cost about 3x more than the same size konigs.
Old 02-03-2001 | 11:07 PM
Post
konig didnt rip nobody, they actually had the design first. the rim you're looking at is advan model7, they are available in the states, try wholesale hyperformance. tell them "john from tulsa, OK" sent u. average price on them are:
17x8 around $430
18x8 around $510
19x8 around $620
my price might be off a little, but im going by last years catalog.
'01 Lexus IS300
'91 Acura NSX
'95 Nissan Maxima
Old 02-04-2001 | 12:45 AM
Guest
Guest
Posts: n/a
Post
17x8 around $430
18x8 around $510
19x8 around $620
thats double the price compared to the konigs.....it might be worth it to get the tantrums and take my chances with bending/worping one then paying 2x the price for he same design. Decisions, decisions, decisions......
Old 02-04-2001 | 02:45 AM
Rice1304's Avatar
Post
well i guess it comes down to if you want to have the "prestige" of the brand name too. For example, would you rather have the real 3 piece Racing Hart C5 rims or a cheap knockoff like the "katana racing 5s" (no offense f=ma haha i had to use that example).
Old 02-04-2001 | 02:51 AM
Rice1304's Avatar
Post
I'm almost sure that konig ripped advan. Nevertheless, konig rips everyone. Look at the ugly konig monsoons which are a pathetic 1 piece immitation of the 3 piece volk AV3s. Look at the konig villains which try to be the SSR integrals, the elan which immitate enkei RF-1s. Not to mention, they have the crappiest names for their wheels -- one of them is called the "five-O."
Old 02-04-2001 | 03:18 AM
Post
believe it or not, konig is moving up in the industry, with their forged rims. by the way, im pretty sure tantrums came out before model7. also, "katana racing 5s" they are made in the SAME building the C5 Evos are, believe it or not. u wanna noe a ripoff brand? tenzo-r
'01 Lexus IS300
'91 Acura NSX
'95 Nissan Maxima
Old 02-04-2001 | 04:13 AM
Rice1304's Avatar
Post
good points. and yes, tenzo r sucks.
Old 02-04-2001 | 02:21 PM
Shoofin's Avatar
Post
Well, I guess Tenzo is off my wish list!
Ed
Pics of my TL
Old 02-04-2001 | 11:49 PM
Guest
Guest
Posts: n/a
Post
Ok, so after a few days thinking about the different rims and sizes I have come to a conclusion. Ever since considering rims I have been observing the actual road itself lately a lot more than normal and think that 19''s will get ruined due to all the pot holes, bumps in the road and various other road hazards and consideringi drive about 60 miles per day for work they'll be ruined in no time. So then I started to look at 18''s instead so I can have a little extra meat on the tires for some added protection. I was playing at discounttire and tirerack and was thinking 18*7 moda r3's with 215/45YR/18 Michelin Pilot Sports. I figured I could order these but the tires are back ordered so i was re-considering the Pirelli PZeros instead. Total price including mounting, balancing and delivery would only be $1800. Then I could pick up some springs from Tim and be ready to roll
Think that should do it?
I appreciate all your feedback (both positive and negative)
Also, btw, the difference between diameters between stock and new would be 0.26% too fast which was a closer match than my combo with the 19'' konigs
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by ArN 2000 TL on February 04, 2001 @ ]</font>
Old 02-04-2001 | 11:56 PM
Rice1304's Avatar
Post
I have heard from many people that P zeroes are a little better than pilot sports (which are excellent tires as well). However, P zeroes will not last as long. you can also try the bridgestone SO2s which are nice. All of these tires are far superior to the other cheaper tires. During the first 1000 miles, you won't notice the difference as much but after that, you will be able to take turns like crazy. I'm very pleased with my investment of these high grade tires. My p zeroes don't even make a screeching sound even if i floor it from a dead stop. I can hear the rubber rubbing off on the pavement but it doesn't make the screech sound because of the excellent rubber compound it is made of.
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by Rice1304 on February 05, 2001 @ ]</font>
Old 02-05-2001 | 12:24 AM
Post
if you guys want good and cheap performance tires, get kumho ecsta 712, they are extremely good and the price is very reasonable.
'01 Lexus IS300
'91 Acura NSX
'95 Nissan Maxima
Old 02-05-2001 | 01:38 AM
speed's Avatar
Post
I've heard that the Ecsta Supras aren't quite as good as the other high-performance summer tires. Do you use them, what's your opinion on them?
Old 02-05-2001 | 02:00 AM
TL909's Avatar
Post
Just wondering, if ArN 2000 TL were to go with the 19s would there be rubbing if the car was lowered?
Old 02-05-2001 | 07:43 AM
Guest
Guest
Posts: n/a
Post
There is another memeber here with 19'' konig tantrums and 235/35's and has no rubbing even with the car being dropped. I am definately not worried about rubbing with the comptech springs (from tim) and the 18''s
Old 02-05-2001 | 09:04 AM
Guest
Guest
Posts: n/a
Question
I've been browsing some posts looking for what tires others have with their 18's and saw a few with the following:
225/40ZR18
Why did you go with this tire size? When playing with the overall diameter between stock and new I found that 215/45's where the best match without throwing off the speedo and odometer. Just curious...
Old 02-05-2001 | 10:38 AM
Post
i have a set of ecsta supra 712 (z rated version) on my maxima for the weekend, it is a great entry level ultra high performance tire, although not the best, it is the best for the money. on my other cars i am using yoko's avs sport s1 and pirelli pzero which are both great tires.
'01 Lexus IS300
'91 Acura NSX
'95 Nissan Maxima
Old 02-05-2001 | 04:00 PM
Guest
Guest
Posts: n/a
Post
Just found out that the 18'' Moda R3's weigh 26.5lbs. Thats what the 19'' konig tantrums weigh...but these are definately higher quality.
Quick Reply: For those with Konig rims
