those with the clear LED spoiler
It's very easy:
1. Remove spolier. There are two 10 mm nut on each side of the wing
2. Remove the OEM LED. 4 philips screws
3. Yank the harness out of the wing. There are some sticky tapes around the opening. Don't be afraid. You might need to pull really hard to get it out. Pull it out until you see the plastic sleeves on the wire. Under them is where the quick disconnects are.
4. Disconnect the OEM LED. Connect your clear LED to the harness with quick disconnects. Check for polarity to make sure it lights up ok.
5. Install clear LED to spoiler with 4 philips
6. Put the wing back, 4 10 mm nut
That's it, it's done
Tatewaki
Tatewaki
Where did you get the clear led spoiler light from? I have been looking for one. asifhakeem34@hotmail.com
Thanx
Thanx
USMC Butterbars
here asif2002....http://spoiler2000.com/Merchant2/mer...tegory_Code=98
quanaman
01-09-2023 07:33 PM
