thinking of maintenance
hey guys im gonna be doing some maintenance soon, and im trying to get a list of what i should do, im planning on doing oil change, spark plugs, seafoam, and radiator flush, are there any other main things i should do? let me know thx
If you post your mileage, it would give us a better idea of what you should do
jus got megan coilovers and put them on thursday, then friday got brand new falken 912 tires, and already have a rear camber kit, gonna order a front one with tax return and full alignment.
i sit low so i needed camber kit
Your car looks clean form the pic, but maybe a nice detail on the outside and inside if you havent done one in a while. Just spend most of a day cleaning every inch of that car ahah, i wish i had the time to do that. I find myself a ltl lazy these days especially with finals and all coming up. Not a good sign. Maybe over spring break ill get a good clean out of my car
assuming you did the timing belt-water pump at 105 there is no need for coolant flush now
If you didnt get the timing belt/wp- thats your number 1 priority now!!!!
Seafoam the oil before change- will really get stuff clean for you-
if you want- install new oil filter then seafoam- drive 100-150 miles and change oil and new filter
Seafoam the gas at 1/2 tank, and manifold vac port-1 can each place
replace spark plugs-ngk irids
flush brake fluid-
flush power steering fluid
3 qts new honda atf in the trans
flush brake fluid-
well the wheels are tucked probly about 1/2 to a inch all around, when i turn my steering wheel all the way my tire jus misses my fender..i cant even put my finger in between( and no rubbing except for when im pulling in a slant and have the wheel turned all the way) so i wouldnt go any lower than that
BlkTxAcuraTypeS
10-18-2015 08:05 PM
