Tensioner Recall
Tensioner Recall
Hi,
Any suggestion if I should bring my car in for the tensioner recall that my vin number was included and was indicated in the acura customer link? Did everyone have this recall bring it in? Or any has this recall and did not bring it in?
Thanks much.
Thanks much.
tensioner recall
Thank you for your input. My car is seriviced by dealer since day one, and did have the oil jet kit installed, but for some reason they never mention about the tensioner untill I registered with acura customer link and found out. Is this something it has to be done? How long did your tensioner fix take? My 03 TL-S is 40k.
Insider- I work for an Acura Dealer. T-belt Tensioner Recall #03-030 usually apply for some 02-03 TL, CL, and MDX. You can find the info at your dealer at no charge or Acura Owner Link Site.
If you are one of the vehicle, please go to the dealer ASAP. I am doing a TL with bent valve, besause owner didn't want to bring it to dealer until it get close to the T-Belt replacement time. The vehicle is only have 33K on it.
Defective Tensioner with leak it own oil and loose it tension and caused to jump timing. Not a good site to be seem.
Need Any Info- Just let me know or E-mail me at HondaDirect02@Aol.com
Is it that fast for them to fix? I thought it is taking all day. because if they don't give me a loaner, then I can't get to work. Tensioner is relating with water pump and timing belt, I don't know if they could get it done in one hour.
tentioner
Originally Posted by Chien
is this only for the states or for Canada as well?
call them up and make an appt to have it done, and ask for a loaner at that time.
I make an appointment and did ask for a loaner but he said immediately without thinking that they don't have loaner. He said they do have shuttle. It is a recall and they don't provide loaner. To me, that is very bad.
Thanks everyone for the input.
Originally Posted by akinaboy
I have a 02 TL-S and when I logged on Acura Customer Service link, my car did not show a recall. Normal? Is the recall inclded on all 2nd gen TL's ?
JGsTL-S,
You don't necessarily get a new timing belt with the tensioner recall. I believe the belt is inspected and if it is still good then they don't replace it.
acutee,
If you aren't getting a loaner from the Acura dealer you're working with try going to another dealer. I always call ahead and schedule and appointment and state that I need a loaner and I have always been given one. Some dealers are too small to have a lot of loaners available although in those cases they're supposed to use Enterprise to get you a loaner.
07-16-2017 08:33 AM
