Tein S Springs
Old Feb 9, 2015 | 12:25 PM
WOLFLIFE's Avatar
Tein S Springs
Going to start off by saying
YES I have looked at other threads for this but I want recommendations on Tein S Springs. I am going the spring way because I cannot afford coilovers at the moment. Tein promises that the car will ride better and the springs will not harm the OEM equipment.
Does anyone have experience with the Tein S Springs? or even the H Springs?
I want to get them when my car gets out of the shop for IA (got hit by a mini van )
Old Feb 9, 2015 | 03:34 PM
Skirmich's Avatar
Why not get H&R for a Mild Drop? Dunno about Tein S or H but my H&R have been more than kind with the OEM Suspension parts and the drop is enough for me.
Old Feb 9, 2015 | 03:42 PM
WOLFLIFE's Avatar
I will look at the H&R springs!
On the terms of rim size what would you recommend with H&R? I have only done research on Tein.
Old Feb 9, 2015 | 09:40 PM
01tl4tl's Avatar
what is your goal with the rim size?
CALL MrHeelToe...Marcus really knows Teins- as his shop is near them and he works on special secret projects and other testing/development work with them!
or Josh at Excelerate
Both will give you honest info based on real life use
Both guys are gearheads who race and have badazz daily drivers
Old Feb 10, 2015 | 11:26 AM
WOLFLIFE's Avatar
Okay thanks!
I just want my car lowered enough with a nice pair of rims so it does not have a gap.
Not trying to slam or anything
Old Feb 10, 2015 | 11:35 AM
01tl4tl's Avatar
no gap is pretty far dropped!!! read some of the related threads
Old Feb 10, 2015 | 04:44 PM
ExcelerateRep's Avatar
Former Sponsor
Not sure where you heard this, as lowering springs of any brand will blow out your factory shocks pretty quickly. That being said, the STech springs seem like they're a good match for you in terms of lowering the car enough to get rid of most of the wheel gap, and the price is right for them.
Since you're going to blow the stock shock pretty quickly with the STech springs, you may want to look into a shock like the Koni Yellows. Keep in mind, the cost of the springs combined with a set of Koni Yellows is actually more than an entry level set of TEIN coilovers with our sale pricing!
STech Springs:
TEIN Springs - STech - Excelerate Performance - Japanese and European Performance Specialists!!
Old Feb 10, 2015 | 06:41 PM
01tl4tl's Avatar
if its a choice of new spring and shock versus coil-over which is new spring and shock with a threaded outer section of the main shock body.
The lower spring perch moves up and down on that threaded shaft = adjusting the cars ride height / drop
Go with the coilovers and if budget allows- the flow rate adjustable ones
Teins are built to be run in that lower section of shock travel and allow the normal full range of travel, that's what's different from `plain` setup, the kind that blows our old stock shocks because its below their smooth operating range= strains seals and blows out!
Teins are made special inside or ?? I'm not an expert, just know mine are fun and the wife likes them.
She drives the car a lot harder than I thought... after inspecting brake pad wear~
As the older guys can attest: Happy Wife = Happy-enough Life for you
Don't forget your lady or man this valentines!!
or suffer the seething unspoken wrath that will be your next few weeks
Old Feb 10, 2015 | 08:15 PM
WOLFLIFE's Avatar
I had a feeling this would be slightly overwhelming...what I want is for my car to be lowered enough to look good and clean with a set of aftermarket rims/tires so I can take her to car meets (Import Alliance this March woohoo) but at the same time being able to drive her almost daily without horrible drive rate and risk of breaking stuff. I've heard people say "Oh get springs I have put over 10k on my blah blah springs and they work great" while others say "get coilovers and spend the extra money cause you can break stuff with springs"
complete noob at lowering cars considering my Integra came lowered so I never bothered learning about it all :|
Old Feb 10, 2015 | 11:29 PM
Alexlee337's Avatar
A buddy recommended me to Raceland coilovers which I have seen some reviews for some on other model cars and they seem to be decent for the price and give a good amount of drop. I looked up how much they would be to buy +'shipping and they only run me for about $450. I mean it's just a suggestion bc in my opinion if you don't like the drop from springs you can't really change it up as with coilovers. I have kept my eye out for decent coilovers like Megan racing & f&f and d2 but for a good amount of money without blowing a whole lot for coilovers, you can take a good look at raceland coilovers.
Old Feb 11, 2015 | 12:23 PM
01tl4tl's Avatar
wait- is this the car that involves mom being driver or passenger?
Maybe take a ride in a few local ziner cars to see how they actually ride
before committing to lowering the car at all
At the car shows- a very clean stock car is appreciated as much or more as a poorly lowered and hacked up fenders car
The car show is a great place to get some free test drives/rides on different systems
ck the REGIONS link to find ziner events in your area. PM a few people and learn a lot!
I took a ziner with a totally stock TL for a ride in mine, suffice to say he noticed a difference in flatness in cornering and quick lane maneuvers, wanted the same but knew the wife drove it more than him = not gonna happen
Old Feb 11, 2015 | 12:32 PM
01tl4tl's Avatar
you are going to wear out parts- not radically break stuff (except stock shock oil seals)
regardless of coilover or cut/lowered springs on stock or aftermarket shocks
The change in steering part and driveline angles puts stresses on their bushings bearings and steel = in ways never intended by the designers
There are parts of higher quality- meant for racers- that will last longer
but low is low and that cost money,, in tire wear--did we mention how the tire edge gets eaten when lower and camber goes negative??? If I get 25kmiles on fronts Im happy
rear tire life about the same, as the camber is worse there, unless you spend more money on camber kits!!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
emailnatec
29
Sep 28, 2018 04:27 PM
CarlosILX13
ILX Performance Parts & Modifications
14
Jul 11, 2016 11:07 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
