TCS switch // bulb replacement
Hello,
I need to replace the bulb for the TCS switch in my 99 RL, it's not lighting up anymore, can anyone please give me some instructions on how to do it? Any help is greatly apprecaited.
A RL should be the same but on the accord/tl/cl you can use a tape covered flat head screwdriver to pry the switch out or you can remove the lower dash cover and squeeze the clips on the side of the switch and pull it out. the bulb is a simple one to replace turn it counter clockwise to remove and clockwise to install.
Always Working In
Yes its really that easy. With the climate control you have to remove the instrument cluster. That's really easy. If you can't find it pm me ill help you.
mada51589
05-03-2022 08:54 PM
Skirmich
09-15-2015 06:41 PM
