TCS not working?
Old Nov 22, 2006 | 12:11 AM
vzuptnguyen's Avatar
B A N N E D
TCS not working?
i push my TCS button but i dont even hear the click you would with any button like that
should something on my dash indicate if TCS is on or not? a light?
Old Nov 22, 2006 | 04:15 AM
MikePA's Avatar
Didn't look in your Owner's Manual before you asked this question, did you?
When you turn TCS off, the TCS icon on the dash lights up.
Old Nov 22, 2006 | 10:35 AM
fsttyms1's Avatar
When you push the button the light on your dash should come on (and when it does that its telling you that the TCS is OFF)
Old Nov 23, 2006 | 11:55 AM
B A N N E D
i guess the button is broken, nothing turns on and i dont hear a "click"
wait, so say the button dont work to turn on and off, then naturally its "on" since i dont see a light?
Old Nov 23, 2006 | 12:03 PM
Hockeyman's Avatar
slobalt defender
there is not supposed to be a click, check behind the panel to make sure the wires are all plugged in.
Old Nov 23, 2006 | 02:51 PM
Edward'TLS's Avatar
6G TLX-S
Maybe the dash light blew. Whenever the car is started, all working bulbs on the dash will light up for a moment for a bulb check. Check if the TCS light lights up at all.
Old Nov 25, 2006 | 01:21 AM
Darkshear's Avatar
l33t
The TCS switch is an electronic momentary switch. The "click" you hear form the sunroof switch for example, is actually the relay, not the switch. No audible feedback from the TCS switch is normal. But yeah, sounds like the bulb is out.
Hell, give it a test. Go find a puddle, or break out the garden hose and wet the tires, and ***MASH*** the gas :P press the TCS button, rinse and repeat. You should notice an obvious difference between "On" and "Off".
Old Nov 25, 2006 | 02:10 AM
B A N N E D
mash?
Old Nov 25, 2006 | 09:18 AM
fsttyms1's Avatar
Originally Posted by vzuptnguyen
mash?
Floor
Old Nov 25, 2006 | 11:18 AM
Blazin_TL's Avatar
Registered User
Originally Posted by fsttyms1
Floor
punch
Old Nov 25, 2006 | 02:12 PM
Darkshear's Avatar
l33t
Originally Posted by Blazin_TL
punch
Stomp
Old Nov 25, 2006 | 02:35 PM
B A N N E D
Originally Posted by Darkshear
Stomp
tap?
Old Nov 25, 2006 | 06:00 PM
MikePA's Avatar
No. Tap doesn't equal mash, floor, punch or stomp.
The goal is to press the accelerator hard enough to get your front wheels spinning to see if the Traction Control System kicks in. Geez, this isn't rocket science.
Old Nov 25, 2006 | 06:02 PM
Trackruner228's Avatar
When you first start the car and all your lights come on does the TCS light come on with all of them? If it doesnt then im going to guess that its just a bad bulb.
Old Nov 25, 2006 | 07:33 PM
B A N N E D
nope it doesnt come on
can someone show me with a picture of all lights that should be on?
also, where can i order the bulbs?
Old Nov 26, 2006 | 04:24 AM
MikePA's Avatar
Read your Owner's Manual or shine a flashlight at the dash and you'll see where the warning lights are.
Old Nov 26, 2006 | 11:42 AM
B A N N E D
oh ok.
Yikes
May 3, 2021 04:29 PM
acurajj
Sep 19, 2015 03:47 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
Allen_442
Sep 8, 2015 06:01 PM
