TCS and ABS lights on??? Help?
Last week I put my foot down to merge into traffic and both the ABS and TCS lights came on. I drove a few miles and turned the car off then back on at a light to try and reset them but that failed. So I finished driving to work, turned the car off then on again and they both stayed off. However, the lights have been coming and going and always come on together. Wife claims that the brakes went out on her a little yesterday. Anybody else have this problem? Aside from taking it to the dealer any suggestions??
Yeah that happened to me today for like the third time since i got the carI havent really looked into itbut all i do is drive a little and they turn off I hope it is nothing bad
The TCS and ABS are tied together because the both use the same wheel speed sensors. If a sensor is going bad it will cause both lights to come on at the same time. Each time you start the car the TCS and ABS perform a self check, if there is no problem with the systems then the lights do not come on. It could mean that a sensor is starting to go bad.
mada51589
05-03-2022 08:54 PM
