Tach Issues
Tach Issues
So I noticed recently that while driving in the range of 30 to 40 mph the tach will bounce up and down about 200 - 300 rpms. The engine will kind of make a vroom vroom noise. This is while in D5. So it did again today and I put it in D4 to see if it would continue to do this. While in D4 it drove fine. The weird thing is that it doesn't always seem to do it in D5 at those speeds just sometimes. Any Ideas. Thanks in advance.
2003 TlS
2003 TlS
is the rpm actually changing, or just the indication?
It seems like the engine is reeving up even though I have my foot at a pretty constant speed.
vroom vroom- please explain
I noticed today that the engine seems to make a noise when this happens like a small rev noise vroom as the tach goes up and then quiet as the tach drops then vroom as the tach goes back up if that makes sense.
is the trans slipping slightly as you are on a hill,, or after its been driven an hour the prob occurs
details details details
first thing for you to know:
on here red text means sarcasm/ often joking harrassment between friends on a typo or error
Not used as a color to highlight answers~
where was the fluid change done- what type fluid?
honda/acura atf or something else
method of changing atf and total qts used?
the battery connections have been cleaned and charging system tested at a parts store? (free)
carry many keys on the key ring?
try wiggling the key... while parked!! can you make it happen that way, meaning bad ign switch
Happens regardless of route taken?- just time since start? every time, only dead cold...any other details to help the band here?
you are talking the speed range where its hunting for 5th gear and TQ lockup is on and off- the ecu wants different than your reality at that moment
Normally if stuck in traffic like situation below 50mph- put it in D4 so it stops trying to save gas
dont forget to go back in D5 when it clears
actual tach jumping.. I leave for our electronic experts to point out where a connection may be at fault or ???
Thanks for the info. It is just kind of weird that it just started doing this as I have been driving the same way all along. The only change that I know of is the cold weather. When you say hunting for 5th gear what exactly does that mean because I am already in 5th gear? Is it possible that it is electrical? Also I noticed that is does this anywhere around 45mph.
So I have really been watching the tach as I drive. I thought it was only 5th gear but it is not. Today I was on a road with a speed limit of 40mph. I started off after a red light and the car shifted normally. All of a sudden the tach was surging when I was moving at about 40mph. I put it into ss mode to check the gear and I was in fourth. 01tl4tl - Does this change your thought about it hunting for 5th gear and trying to save gas? Please let me know because I it could be serious (beginning of tranny failure...again) I would like to take it to Honda/Acura asap as I put many miles on my car daily. Thanks again for all of your help.
I have briefly put it into d4 after d5 was surging and it did not do it once in d4. I will try that again today and let you know what I get for results. What does that mean when d5 surges and d4 doesn't?
What exactly does that mean? The cars throttle response is great in d4 but sometimes in d5 it isn't good at all unless I really get on it. If the 5th gear pack is going then why does it surge when in d5 and 4th gear? Thanks again for your help.
if its one clutch pack- its all of them
that means the friction material has worn off the disc- the grabbing/slipping feeling is them trying to grip and hold to engage the trans
if its a worn pack set, its total rebuild time and new Torque Convertor, as the particles will have plugged its outlet screens to the system that makes the trans actually work
expect a low of $1500
( ziner found that shop quote Please ck in with results)
to a average high of $2500- even $3500 has been reported!!
(major reason for cars value decline=trans issue)
depends on how many parts it needs- you cant tell for sure on auto trans until its in 100 pieces on the workbench- clean and measure-inspect everything...
of course you can have many other things wrong that will make your symptoms
thats why a trip for free inspection would be next
they ck for codes and test drive looking for specific symptoms. ck the cv axles etc for you to find the problem
Thanks for the info. What are other symptoms of the clutch pack going bad? Does it make sense that d4 drives fine but once in a while d5 does the surging? What would I look for in the cv axels? Is there anything else that I can check. I have loss some throttle response while in d5, does that go along with the clutch pack going bad?
meaning what- you push the gas and it doesnt come out of `overdrive`tc lockup, and start to go faster right away?
Have you cleaned the TB air plate inside it, hows the spark plugs?
ever run good cleaner thru gas or manifold vac port?
air filter clean- all basics covered right--tire pressures..no broken motor mounts
symptoms of pack wearout: slipping-revving under load, doesnt want to engage or hold--
example: full throttle getting on freeway from 20 mph and stand on it, whats it do
evidence of material in fluid change
flashing D5 light on dash probably with slipping of clutch
code for engine overspeed, but not in limp mode and runs fine,,never over revved
(we do have a rev limiter, but it could fail)
doesnt want to shift on longer drives as material clogs the TC outlet screens
(if that happens- park and wait 30-60 minutes)
You can take a 3 ounce sample of atf and have a lab like blackstone test it!
Also the amount of metal and whats in it,, on the drain plug magnet- will tell wear inside
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
