synthetic --> regular 1 oil change...problem?
Hi, I went to the acura dealer today for an oil change, took my oil and filter, and told them to change it, and to top off other fluid.
came out, they said they topped off fluid, but i noticed they didnt use my oil or filter, so i bitched, and the service guy said he wouldn't charge for the oil change, and refunded my money.
Well 2 things. they didn't top off any of my fluids. I specifically asked them to check the tranny fluid, and it still is right below or at the min level recommended. the antifreeze was still very low. so im gonna go back to them for that.
but the main question is should i go change my oil back to synthetic now, or just wait till the next oil change? What happens if you go from synthetic back to regular oil (i used synthetic only 3 times so far, before that it was regular oil.) if it matters, i have about 89,400 miles or so.
thanks
thanks
nowadays all synthetic oils are fully comptatible with conventional oils. You can even mix them together if you wish (by doing that you will obviously lose the benefits of the syntehtic oil, but it should not be harmful to your engine).
If I were you, I would change it after 3K miles and go back to synthetic so you can get longer drain intervals.
CTS-V Import Slayer
thanks
thanks
IBankMouse
06-13-2020 12:53 PM
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
Joe Avesyan
09-29-2015 03:57 PM
