Sway and strut tie bar questions
With the Comptech sways, it's like night and day. Very noticeable change in body lean. Don't have the strut bar so I can't comment on that. Ride with the sways is slightly more firm when going over uneven pavement.
Having Fun?
Here's a long thread discussing the upper strut tie bar: http://www.acura-tl.com/forum/showth...+strut+tie+bar
Sways are a must IMO! Makes night and day difference (for the better).
Upper strut tie bar with stock sways/springs won't make a noticeable difference. Combined with better sways (comptech) it makes steering a little more tighter.
Purchased: April 28, 2001
Originally posted by bricot
We have stock sways, however, the Comptechs are thicker (stiffer) which makes a big difference in getting rid of body roll.
If you were selling these don't forget to mention that or it may be considered fraud.
Originally posted by edgalang
WARNING...Don't forget that it only applies to the rear bar.
http://www.acura-tl.com/search/resul...eid=suspension
Originally posted by WiLz
huh? only rear? then y is there a front one for the neuspeed?
Originally posted by Brewboy
So are you too saying the wall thickness is the same between the front stock bar and comptech's or only the outer diameter of each is the same?
As for the sidewall thickness of Comptech's...No comment (although I've already made my personal judgement on the matter). But...I can relate to those who have them and would similarly be upset if I found out that one-half of my $300 set of sways are the same as stocks (especially if I'm a TLS owner). No one has verified the thickness...nor would anyone want to for obvious reasons.
Remember...these bars were originally made for the accord...so it wouldn't suprise me one bit if the stock accord front sway bar were smaller than ours (then it would make sence if all comptech did was increase the overall diameter but keep the bar hollow to save cost).
So...a TLP owner who bought the comptech set WILL notice the difference in the ride alot more than a TLS owner of the same setup because the TLS rear bar was thicker to begin with.
If you were butt poor and just wanted to do something over the weekend, ask a fellow TLS owner to give you his bar and bushings (That's what I would do if my brother in-law ever buys his V6 accord).
Stats on OEM sway bars.
OK...so everyone seems to be all hyped in getting new sways Comptech, Neuspeed, Eibach...whatever. What if you cant afford it? Ask someone for their stock bar next time you attend a MEET!
Like Comptech and the OEM manufacturer have prooven...changing the rear bar sometimes is all you need to dramatically change the suspension dynamics. Here's a breakdown of the differences in each model.
Accord Sedan (4-cylinder)
Stabilizer Bar (mm,front/rear) 26.5/16.0
Accord V-6 Sedan
Stabilizer Bar (mm,front/rear) 27.2/16.0
Accord Coupe (4-cylinder)
Stabilizer Bar (mm,front/rear) 26.5/17.0
Accord V-6 Coupe
Stabilizer Bar (mm,front/rear) 27.2/17.0
3.2 TL-P
Stabilizer Bar (mm,front/rear) 27.2/18.0
3.2 TL-S
Stabilizer Bar (mm,front/rear) 27.2/19.0
Comptech
Stabilizer Bar (mm,front/rear) 27.2/22.0
So imagine...a lowly guy with an Accord LX who knows a friend with a TLS can get a beefed up suspention upgrade for FREE!
Accord V-6 Sedan
Accord V-6 Coupe
3.2 TL-P
3.2 TL-S
Comptech
Originally posted by DHB
Is it the Comptech or Neuspeed sways that are solid?
As for the front..the ONLY bar that has been verified to be solid is Neuspeed.
trying to get a lil V-I
edalang
Quick question for you, since it seems you did the most research.
The OEM sways, both front and rear, for a TL-S will fit an Accord correct?
Will the OEM sways (f/r) for a CL-S also fit an Accord? And if so what generation Accord?
I understand there is a diameter difference, which will help the Accord. So I was hoping to sell off my OEM CL-S sways so that I can afford the Comptechs.
Thanks in advance.
editNevermind. I answered my own question. I went to www.comptechusa.com and looked up part numbers for CL, TL, and V6 Accord. For all three vehicles listed above the part numbers were:
- Sways 140-215
- Springs 110-215
So my guess is they are interchangable...anybody else know otherwise?
Thanks in advance.
- Sways 140-215
- Springs 110-215
Originally posted by chikai
So my guess is they are interchangable...anybody else know otherwise? [/B]
Re: Stats on OEM sway bars.
Accord V-6 Sedan
Accord V-6 Coupe
3.2 TL-P
3.2 TL-S
Comptech
Accord V-6 Sedan
Accord V-6 Coupe
3.2 TL-P
3.2 TL-S
Comptech
Re: Re: Stats on OEM sway bars.
Knowing the outer diameter of a bar is fine for comparing only solid bars and assuming the same material or similar. Concerning hollow bars (fronts), you need to include the wall thickness in order to calc the cross-sectional area of the bar to be of use in the formula to determine overall stiffness. It is incorrect to only compare the outer diameters of hollow bars to determine its stiffness.
P.S.
I agree with you in that it would be hard to measure bar stiffness in relative to each other if different manufacturers produced different bars for the stock Accords and TLs since you wouldn't have a baseline...but you are forgetting the fact that this is not the case and that HONDA makes all the bars for these cars.
What it basically comes down to is that HONDA makes 2 different front bars and 4 different rear bars that will either fit an Accord or TL and that someone who has the thinnest/softest of the 2 bars (an Accord LX sedan most likely) would greatly appreaciate our stock ones that we dont use anymore.
marcelft
07-10-2018 06:17 PM
acurajj
02-14-2016 02:28 PM
MonkeyTrucker
09-21-2015 06:15 PM
