sway bar install
sway bar install
sorry about this, but i just recieved my comptech sways and the search feature doesn't work well.
does anyone have the link to the thread with pics?
thanks
BTW: did they forget to include teflon tape or am i supposed to buy it seperately?
thanks
Yeah Email me... NYDESI80@aol.com I'll get you the link.. .I can't post it up here due to censorship. Or instant messge me.
Dragging knees in
Teflon tape doesn't matter. It wears out in a few months and the bushings start squeaking, anyway. Go to an auto parts store and get a can of white lithium grease. It's like 4 bucks for a big can that will last your lifetime. Spray that on the sway bars (where it meets the bushings) and on the inside of the bushings, too.
Rear one is very straight forward. The front, you have to take the sway bar out up over the catalytic converter. Play around for a little bit and you will get it out. But make sure you remember how you took it out, so you can backtrack and put the new one in. Wrap the new one in saran wrap to avoid scratching. Granted you will see it like two times for the rest of your life, but it's just nice to not get scratches on the new parts.
It WAS in the DIY section. Wonder when that will come back. They should of had the teflon tape, I got it and about it wearing out? I don't hear any squeaks after 9 months or it just may be because I have the music too loud.
just a note..
to get the front sway out and the new one in.
u have to roll the sway bay backwards...so it point backwards, to get out over the exhaust pipe.
but to do this you have jack the car up very high.
i did mine using a floor jack.
if you're on a lift,it's not an issue.
cheers.
cheers.
Originally Posted by Joseph_99TL
just a note..
cheers.
cheers.
u can do it jacking up one side of the car...
i did it.
it was just a little scary maxing out the floor jack!.
not sure about ramps.
don't think they are high enuff.
i did it.
thanks people, you are a big help.
i wish that thread with the pics were still here, then i could print them out.
now i need to pick up allen wrenches, a jack, some stands, and pblaster or put some atf in a bottle to loosen up the bolts.
get the socket allens..
the little l-shaped allens aren't worth a shit.
and don't strip it!..
or you're f'ed.
how old is this car?.
i have a 99.
it helped me to clean the thread with a wire brush and soak the link alot before loosening it.
and, it may be very tight the whole way off the link.
be patient.
and get a box end wrench...
or you're f'ed.
i have a 99.
be patient.
marcelft
07-10-2018 06:17 PM
MonkeyTrucker
09-21-2015 06:15 PM
k6biv
09-10-2015 06:37 PM
