Sway Bar Endlinks
Sway Bar Endlinks
How do I get these things off of the sway bar and the suspension fork? The bolts do not back out, they just spin...
Is there a trick here?
I'm trying to replace my swaybar and various other suspension components., but these are giving me a bit of trouble.
AZ Community Team
Received 7,771 Likes
AZ Community Team
OEM.
Front (List $31.22; Wholesale $23.42)
51320-S84-A01 LINK, R. FR. STABILIZER
51321-S84-A01 LINK, L. FR. STABILIZER
Can't find the rears. They should be here:
http://www.acuraautomotiveparts.org/...s=&view=normal
They're in the drawing, but not in the item list.
I'm a thrill seeker in my
Just cut off those POS oem ones and use MOOG end-links as recommended. They're phenomenally better than the oem ones. I have a set on the rear with an Eibach rear sway and it's been fantastic since install.
Mines stripped so I had to POP that little bastard out of the joint so I could Install my new Rear Struts, Used a Caliper pressure tool to put it back together. The little rubber part covering the joint was damaged in the process but doesnt matter im saving for the MOOGs until i have them, My Eibach ARBs are sittin there useless on my garage.....
Shit Happends....
Shit Happends....
+1 on the vise grip.
Grab the stud on the sway bar side of the link and clamp down over the rubber boot to hold it from spinning.
Yes you will destroy the boot but your replacing the link anyway.
