Sway Bar Dimensions
Are you asking for the factory bar diameter?
Most are 21mm and the replacement upgrades are 23mm
again I ask- do you need the diameter of the bars or what?
ok that is called diameter
check the website for aftermarket sway bar makers to find the actual size for your year
Here you go:
http://www.hondanews.com/categories/...4?archive=2003
Front:
TL-P and TL-S
1.07 in./ 0.18 in.
(27.4 mm) diameter x (4.5 mm) wall thickness
Rear:
TL-P
0.71 in
18.0 mm diameter, solid
TL-S
0.75in.
19.0 mm diameter, solid
Front:
TL-P and TL-S
1.07 in./ 0.18 in.
Rear:
TL-P
0.71 in
TL-S
0.75in.
it may be that aftermarket ones are 27mm solid... so i must assume stock are hallow... can anyone verify this for us... so then the aftermarket ones do make a difference if i'm not mistaken....
Start with the upper strut tower bar and lower frame stiffner from MrHeelToe if you want to build a strong car for better cornering.
Reduced frame flex is the base for a good handling ride
Wallace, LA
The car comes with a 4 point upper strut tower bar stock...
Originally Posted by L3wD
then it isnt beneficial to get a new front sway is it... since the aftermarket ones are 27mm
Originally Posted by TLsu
The strut tower bar is the last thing you should buy for the ua5 to increase handling
These will greatly reduce body flex in the rear and the sways will reduce some off the roll front and rear.
http://www.cusco.co.jp/english/e_cont.html
Wallace, LA
Originally Posted by mcflyguy24
2nd Gen TL's have front and rear sway bars, no 4-point strut tower brace though...get some good thick solid sways and some cusco rear lower arm bars.
Dragging knees in
Comptech sway bars are 27/22, but the wall thickness is higher than the OEM bar in the front. Rear is thicker and solid.
I don't have any chassis braces and I don't think it's really necessary. I didn't experience the need for it, and I've put my car through a lot.
Granted, it wouldn't really hurt, but you're not going to see any huge improvements, either. The front already has a 4-point brace, and the aftermarket rear lower braces you see are so fucking flimsy, and the mounting points aren't really going to get any support from those tiny little bars.
Just pop the hood and you'll see we have a 4pt strut tower brace...it's so easy even a caveman can do it.
Originally Posted by Pure Adrenaline
Pop the hood and look again.
![](http://i31.photobucket.com/albums/c390/Scott2322/th_e_lower.gif)
I think it has more to do with the design and less to do with thickness. If you notice the ver. 2 system make use of an A-frame which is very strong due more in part to the design itself rather than wall thickness. Strength comes in triangles. Sure it's only a minor upgrade, but really does compliment sway bars, coilovers, ect. Just an option. I'll shut up now though, cos' I'm not willing to go look behind my rear axles next.
Eibach: http://eibach.com/cgi-bin/htmlos.exe...9580900009485?
Front: 27mm tn
Rear: 23mm sn
part # 4040.320
Neuspeed: http://www.neuspeed.com/products/product_list.asp?app=5|TL&type=2<ype=ns_import
Front: 27mm/ part # 15.20.27.1
Rear: 19mm/ part # 25.20.19.3
Comptech: http://www.comptechusa.com/store/140215tl.html
Front: 27
Rear: 22
part # 140-215
Front: 27mm tn
Rear: 23mm sn
part # 4040.320
Front: 27
Rear: 22
part # 140-215
Not quite sure where you guys are getting your info. This is an '07, right?
According to the Acura website, under specifications, it lists:
BASE: Front: 27.2mm diameter, 5mm wall thickness
Rear: 18.3mm diameter, 3.0mm wall thickness
TYPE S: Front: 27mm solid
Rear: 20mm solid
Just for shits & giggles, the rear bar on the Type "S" is the same as my '05, which, since it is a 6MT comes with the A-Spec suspension. The front bar is also the same diameter, only my '05 is not solid. It is a 5.0mm wall thickness.
The automatic (non-Aspec) came with 25.4mm/4.5mm thickness on the front.
The rear was 17mm solid.
Rear: 20mm solid
Check the Off Topic section (link at top of this page) then Sponsored Sales for Progress sway bar post by Excelerate
It list the stock size bars and the size of the Progress bars
What is the diameter and wall thickness of the 2002/2003 TL-P and TL-S front sway bar?
Originally Posted by bonknhead
Here you go:
Front:
TL-P and TL-S
1.07 in./ 0.18 in.
Rear:
TL-P
0.71 in
TL-S
0.75in.
Front:
TL-P and TL-S
1.07 in./ 0.18 in.
Rear:
TL-P
0.71 in
TL-S
0.75in.
Wallace, LA
The diameter and wall thickness for the FSBs were post #7, remember?
![Snipe](https://acurazine.com/forums/images/smilies/snipe.gif)
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
