Suspension Mod Question
Old Apr 15, 2004 | 03:32 PM
Booker's Avatar
I just had Tein High Tech springs installed and changed my stock tires to Conti Extremes (stock sized) on stock TL-S rims. I went with Tein, because the drop was minimal (1.5" rear, 1" front) and I was told I wouldn't need a camber kit for the drop amount.
I'm quite happy with the results. The car handles turns/curves noticeably better with a lot less body roll, and the tires definitely grip better.
My questions are as follows: although the car handles better through curves, it almost seems like it drifts a bit on straights (100 miles of NJ Turnpike driving daily). I seem to think that someone mentioned overinflating the Contis to help with this. Any truth to that? Also, the car seems like it feels "lighter" in the front. Would an alignment be recommended after having the springs installed or is it not necessary?
Finally, I'm now considering doing more as far as the suspension is concerned, and it seems as though a lot have recommended sway bars (I looked at the earlier thread about stock TL-S suspension). What would be the recommeded bars for someone who has not dropped the car so much?
As always, thanks for the help. This site it great!
Old Apr 15, 2004 | 03:33 PM
`ill*tl's Avatar
Yes, you are supposed to get an alignment check after you put springs on...get that done ASAP.
TLDude876
Dec 28, 2016 03:18 PM
BoricuaTL
Apr 8, 2016 01:08 PM
datadr
Sep 12, 2015 09:12 PM
Nicho863
Sep 3, 2015 09:16 PM
