Suspension
Old May 8, 2014 | 10:14 PM
Mathreef's Avatar
Suspension
Hy can I use accord 2002 suspension on my TL 2003?
Old May 8, 2014 | 10:20 PM
Skirmich's Avatar
You sure can... At least the shocks are PnP..
But I believe the Springs are tailored for the more heavy TL.
Most others suspension components are the same.
Old May 9, 2014 | 06:36 AM
Mathreef's Avatar
Because I fond Mugen suspension
Old May 9, 2014 | 06:37 AM
fsttyms1's Avatar
The 4cyl suspension isnt recommended for the heavier TL, the springs will sag. Even H&R discovered this with their springs and had to make a set specially for the TL
Old May 9, 2014 | 02:40 PM
Mathreef's Avatar
Well it not fit???
Old May 9, 2014 | 05:21 PM
3.2TLc's Avatar
Fit, probably....but is it engineered for the 4 or 6 cyl model ?
Old May 10, 2014 | 02:31 AM
Skirmich's Avatar
Don't use any specific Shock/Spring setup for the 4Cyl Accord on the TL.. By pure Logic.
Old May 11, 2014 | 02:53 PM
Mathreef's Avatar
It's for v6 model
Old May 11, 2014 | 04:06 PM
Skirmich's Avatar
Then it should be good fitment wise..
Though the Accord V6 and TL aren't the same weight.
In some cases the TL is almost a whooping 300lb heavier Wet vs V6 Accord..
And that demands different Springs ratings altogether.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
lanechanger
Oct 13, 2015 10:56 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
adreano17
Sep 29, 2015 08:48 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
