Suspension
Old Apr 22, 2001 | 11:03 PM
jz983's Avatar
Red face Suspension
whats the different between the strut bars, sway bars, ground control, anti-roll, damper...etc?
Old Apr 22, 2001 | 11:09 PM
unx979's Avatar
Post
strut bars - gives more support for the body when you lower your car cause when you lower it, it puts extra stress on the body of the car. The strut bar helps strengthen the body and prevents twisting of the body.
sway bars - they're used for improved handeling, i'm not too sure how they work, it basically helps with the handeling of the car.
ground control - down force stuff
the rest are all stuff i'm not too clear about.
Old Apr 23, 2001 | 07:50 AM
Brewboy's Avatar
Post
As mentioned, strut bars stregthen the body to prevent twisting. The TL has one -looking in the engine bay, its the black tubular bar running L/R between the top of each strut tower.
Sway bars and anti-roll bars are the same thing. They tie the body to the suspension thus the stiffer the bar, the less body roll or body lean while cornering. Your TL has them too, but they are not as stiff as Comptechs.
Ground controls is a brand name of a sleeve-type coil-over.
Damper is usually another name for a shock absorber.
Old Apr 23, 2001 | 12:59 PM
jz983's Avatar
Post
thanks for the input guys. are you talking about the 1st gen tls? or the 2nd cause i have a 1996 2.5. thanks again. w
Old Apr 23, 2001 | 01:35 PM
jz983's Avatar
Post
i've got a 96 2.5 TL. I want to get new, stronger struts. Anyone have some input? if you have changed your struts, and improvement. etc? some feedback please.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
lanechanger
Oct 13, 2015 10:56 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
adreano17
Sep 29, 2015 08:48 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
