Supercharger questions
1. Hey would i benefit from flarger injectors ? I want to keep about the same gas mileage but dont want to fry my motor by having stock 330 injectors
Would i benefit from buying a set of 440 Bosch Greentops?
2. can i still use my aem with comptech supercharger?
3. how much can i boost before i need to start building the motor ... i want to be around 10psi ... i was told i need an intercooler .. what else though
4. where can i get some cheap but nice gauges for my car .. fuel pressure regulator .. and boost
5. Im thinking about putting the boost inside the middle ac vent ... like buring it behind the vents (so the vent is still functional) and connecting it to a switch so i can activate the light on and off. The middle vent seems to never blow nearly as hard as the others anyways ... Will the constant cold air effect the acuracy of the gauge?
Also i need to find a place to house my fuel pressure gauge ... where can i put this... keep in mind SLEEPER ... anyone have any ideas ... i thought of the cupholders, but thats to obvious and i need them
thanks guys
thanks guys
Comptech Freak
it comes with icebox so i think it is better gain than AEM
and it won't be the same gas mileage for sure, supercharger usually gives 3-4mpg less than usual
thats if im on it all the time i thought ... if i run it in vacuum and dont boost much then it shuoldnt be any different ?
no no dont do it dont know
yea it does .
btw it wont work in the sunglass holder .. i had the vafc up there and thats about all you can fit up there
plus i want it to be sneaky the sunglass holder was a thought at first .. but people like messing around with stuff when they come into my car so im sure theyd see that
[QUOTE=Hurleysurf24]
Larger injectors would allow you to lower the fuel pressure closer to where it is without the fuel pressure regulator. Your stock injectors are not 330s, They are more like 250-270. You need to grind the fuel rail to fit larger injectors.
Not without cutting it apart and fabricating a way to make it bolt up.
You'll need 440cc injectors, intercooler, e-manage, and a VERY GOOD tune to keep the car reliable for daily driving.
You won't find gauges cheaper than the ones I'm selling.
No problem mounting it there except it'll be a PITA to do.
Originally Posted by MikePA
Doesn't the fuel pressure gauge require a fuel line be routed to it?
No it doesn't it is an electronic gauge. There is a 3 wire electrical pressure sensor.
Originally Posted by Hurleysurf24
thanks but yea ... i can find cheaper gauges .. just dont know how quality they are lmao
Originally Posted by mrsteve
You get what you pay for...
i ended up buying electrical greddy boost and fp gauges 52mm
also what the hell is the translation in measurement for the fp gauge .. it measure 1-2-3-4-5-6. .... what are the translation to regular psi measures ie 10-20-30....100
where should i be sitting at stock ?
navtool.com
31
11-16-2015 08:30 PM
lanechanger
10-13-2015 10:56 AM
navtool.com
09-25-2015 05:15 PM
