Sunroof Motor
Old 05-01-2008, 03:02 PM
pgolfco's Avatar
Question Sunroof Motor
I searched other threads and could not find a specific problem like mine, so here goes......
I have a '99 TL with just over 100K miles. The sunroof is very difficult to open and close and it sounds like the motor is very strained when doing the work. It sometimes stops completely half way through opening and closing and I have to force it by hand the rest of the way. I have tried lubricating the tracks with silicone grease, as the dealer suggested and it only worked for a short amount of time.
I am wondering, does the sunroof motor need to be lubricated as well and if so, how do you get to it? I am hoping that it doesn't require the removal of the headliner!
Thanks in advance for any help!
CP
Old 05-01-2008, 03:53 PM
NSXNEXT's Avatar
Received 1,080 Likes on 661 Posts
yes you need to clean the rails and lube them with white lithium grease.
Old 05-01-2008, 05:49 PM
I don't sleep...I wait
PiKap335's Avatar
This actually happened to me and I thought it was the motor as well. It turned out there was a piece of metal stripping that had come loose and was getting stuck between the cloth cover of the ceiling and the glass. Open it up all the way and look around for anything loose...or any screws missing. Sorry I can't give you more detail - it's been awhile since it happened and I'm not by the car right now.
Good luck.
Old 05-01-2008, 11:27 PM
ChampionFiyah's Avatar
funny this happened to u, cuz just today i was driving and i went to put the moonroof in the pop-up position and it would not go up at all. so then i hit the other button to put it in the slide-back position and it worked, so i closed it back and tried to put it in the pop-up position again and it worked??????? why that happened?
Old 05-04-2008, 09:17 PM
ABPUA5
-Vip3r-'s Avatar
^because your sunroof wasn't completely closed.. it happens
08KBP_VA
10-22-2019 01:55 PM
juanrl
09-29-2015 03:25 AM
xsilverhawkx
09-28-2015 06:51 PM
Quick Reply: Sunroof Motor
