Strongarm hood struts
I saw these on Rockauto and ordered two of them from Amazon
Both struts are exactly the same and both will only fit the driver's side. Is there a way to rotate of the ends so it fitshe passenger side.
I've found no mention of left and right in the part numbers. It seems to be 1 part fits all.
Unregistered Member
I ran into the same problem.
So what you need to do is the following:
Step 1: Install the driver's side
Step 2: Take the leftover part in your right hand
Step 3: Pass it to your left hand while rotating it
The end result will be a product that will fit the passengers side
Thanks for the encouragement
I got it to work by attaching one end to the hood and rotating the assembly so the two ends face opposite directions instead of both facing the same direction.
I installed the 6322 last year. I hope the quality is good and I can get at least 5 years out of them.
lanechanger
10-13-2015 10:56 AM
