Strange Vibration
Old Apr 3, 2010 | 07:43 PM
jrdecat's Avatar
2000 TL-P
Strange Vibration
So a few days ago my 2000 TL-P started making a strange vibration from under the hood. I could tell that it was coming near the right side of the engine. It only happens when I step on the gas as the engine revs up. Once a steady rpm is reached, the vibration stops. After popping the hood and revving the engine with my head under there, it seems the problem is coming from the accessory belt tensioner. Not the pulley, but the tensioner itself. I can see it vibrate as the belt applies tension during revving and then it stops when the constant rpm is reached. Does this mean that my tensioner is about to give me all kinds of problems? Any ideas? Just replace it and go on? The red markings indicate where I can see the vibration taking place during revving.
Old Apr 3, 2010 | 09:42 PM
01tl4tl's Avatar
mine went out- accessory/ac belt tensioner assembly, 85 dollars at local import parts store
you want the complete assembly not the pulley- its the tensioner thats failed
It is supposed to keep a constant tension on the belt thru the rpm range
If it sounds like a V8 under the hood- thats the problem
replace the belt too- its due on time if tensioner has quit
Old Apr 4, 2010 | 01:38 PM
jrdecat's Avatar
2000 TL-P
Thank you 01tl4tl. I'm assuming that you've got to take out a lot of stuff (side motor mount, etc. ) to get to that thing. The belt is only about 7 months old. I changed it when I did an engine swap last year.
https://acurazine.com/forums/showthr...ng+belt+melted
Yah, I'm that guy. I don't remember exactly how that tensioner is fastened on to the motor, but I'm sure I'll figure it out. Time to dig out the manual!
Thanks again!
JR
MrHeeltoe
20
Feb 23, 2023 01:54 PM
mlody
Dec 4, 2019 02:11 PM
joflewbyu2
Oct 8, 2015 11:16 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
