Strange tranny clunk after killing engine
Old 10-19-2007 | 06:41 PM
beeker's Avatar
I just got 52,500 service for my 2003 TL at the dealership--told them about a strange clunk/metallic rap/thump that occurs intermittently after stopping, putting in park, then turning the engine off. The sound started soon after I had my non-Acura mechanic change the oil (about 4 months ago). The sound happens about a half second to one second after the engine is off, and sounds like it's coming from below the gearshift. Dealership told me it was a "solenoid activating"unexpectedly. They replaced it under warranty, but the clunk sound remains (again, intermittently) under the same scenario. Anybody else experience this?
Old 10-20-2007 | 05:18 PM
orgnlprankster7's Avatar
08 Civic SI
i have the same, im pretty sure its normal, the tranny locking in park?. for me at least its when im in park the car will roll a bit (inch or so) and stop and thats when it clunks/makes a click under the shiftgate. maybee someone with more knowledge can chime in on this one.
Old 10-20-2007 | 10:40 PM
eyesnake02's Avatar
Yea I think The tranny is locking in park. I should be normal
Old 10-21-2007 | 07:53 AM
01tl4tl's Avatar
Put the parking brake on fully, and let the car take a set on it, before puttring in park- that eases stress on the gears. The park brake is a mini set of drum brakes inside the rear rotors center hub.
Imagine whats going on internally when the car rolls into the lock/park position
The motor mounts on some years are vacuum assisted and make funky noises on start and shut down
If you took it in for warranty and its not fixed- go back- sometimes the new parts fail or there is a secondary problem CAUSING the part failure, which the dealer wouldn't know until you come back in and tell them
Old 10-21-2007 | 08:47 PM
acutee's Avatar
To avoid the clunking noise, turn off engine before putting in Park. Normally, it happens when you tried to put it in Park after a few minutes in other position. If you did drive it for a while, you wont hear the clunking noise when shifting it in Park, right? If you did shut off the engine, then it is just rolling, and locking gear in place.
Old 10-21-2007 | 09:46 PM
01tl4tl's Avatar
Ahhh NO
Dont turn off the engine first-
Apply park brakes- put it in park- then stop engine
and if the noise ever changes or gets worse- its a signal that something is wrong
The motor mounts fail- just like the trans- thats usually when the tech spots it and its way cheaper to change it then with the trans removed and out of the way
Old 10-22-2007 | 08:29 AM
Billy Sacco's Avatar
Kilos of yayo in
Thats exactly what I was told by a mechanic a long time ago. I always do this and have never heard a clunk like you guys are describing. The less stress you can put on these trannies the better I figure.
Yikes
05-03-2021 04:29 PM
marcelft
07-10-2018 06:17 PM
01CLOwner
10-09-2015 01:07 PM
1Lieutenant
4G TL Problems & Fixes
09-10-2015 08:39 AM
HeloDown
09-08-2015 06:51 PM
Quick Reply: Strange tranny clunk after killing engine
