Stock Suspension
Stock Suspension
Is the stock suspension in the TL-S any better then the TL-P? I know that the front sways are the same (according to the brochure), and the back sways are slightly thicker, but there is no information as far as spring stiffness. I would assume that the TL-S has stiffer springs than the TL-P.
If I'm correct, the TL-P suspension is unchanged over the 2001 models, so I believe I'm accurate regarding what I'm about to write.
I've driven my friend's a 2002 WDP TL-S and you can definitely feel a difference in the suspension. It is noticeably stiffer.
4drviper
09-23-2015 07:42 PM
