stilll have a problem....
Old Oct 21, 2004 | 12:23 PM
SilverIce2000's Avatar
ok heres the thing...
i got a new battery because the old one had acid comin outt... the thing is, the old terminals- i duno if thats what you call it but its the round things of the positive and the negative that connect to the battery, looks like it has a lot of acid or rust on it... and i think the sensor doesnt touch correctly because when i open the ring to put in the power wire of my amplifier, the car doesnt turn on... but if i take out the power wire, it works... and hten to test to see if the problem was hte power wire, i turned off the car, touched the power wire of the amp on the battery and turned it on and it truned on... SOo the power wire is not the problem... Do you think i should chnage the terminals or just clean them off??? also, what type should i get if i should change and is it hard to install?? please help me outtt ... its getting cold out i wana fix this problem
thanx guys
Old Oct 21, 2004 | 12:33 PM
Beeza's Avatar
1 B3AKOHE
http://www.ehow.com/tips_10758.html
Some people recommend using a baking soda/ water mixture but you take a chance of neutralizing the battery acid and making your battery weak if not done properly.
Old Oct 21, 2004 | 08:23 PM
thanx BEEZA....
so im gona follow that websites advice, and not get new ones... just clean the original ones i have... ill give it a shott
thanx
Old Oct 21, 2004 | 09:16 PM
alleyesonmeee's Avatar
MIA
clean the terminals with steel wool and then spray w/ WD-40
kthai417
Apr 6, 2019 11:38 PM
mav238
1G RDX (2007-2012)
34
Jul 29, 2016 08:24 PM
DecaFe1
Dec 14, 2009 03:56 PM
No_Lmtz
Jul 14, 2009 11:25 PM
HaPPy jU1cE
1G TSX Photograph Gallery
44
Sep 3, 2006 11:46 AM
