Steering wheel is shaking when braking, What's the deal?
Whenever I'm cruising at speeds of about 60 and I brake my steering wheel shakes pretty bad. Anyone else ever experience this?
Dr. TLS
Re: Steering wheel is shaking when braking, What's the deal?
Re: Re: Steering wheel is shaking when braking, What's the deal?
Originally posted by vandy786
Probably rotors. Do a search. Lots of info.
warped rotors, bring it to the dealer and see if they will replace them
Warped rotors just need to be resurfaced. The reason why dealers don't replace them is because they aren't throw aways. There is enough meat on them to turn em. Now if you had several cuts already and the rotor is below spec then you might get new ones, if the tech doesn't find a stuck pad or a hung caliper more then likely its your driving habits... you pay after several cuts.
Just had my brakes replaced by the dealer. $360 for pads, 4 new rotors, etc. Mine weren't under warrenty (53k miles here). I've had my rotors resurfaced several times and they were damn thin when I went in for a brake checkup. They needed it. Be prepared to pay though...
My 2002 TL/S was doing the same thing @ 21,000. Took it in and they did a complete 4 wheeel brake job with new pads under warranty. But plan on leaving it with them............I was there 4 freaking hours!
The rears were worn pretty bad too. I was thinking about getting performance rotors and pads while I was replacing them but I have a hard time investing $$$ into this car since I don't plan to keep it for much longer. I'll still take care of it though.
Originally posted by peiqinglong
Why would you need new back rotors for? They almost never warp. The fronts do 90% of the braking. should have gotten some crossdrilled and dimpled rotors with some Endless pads.
