steering volume control problem
Old Jun 26, 2007 | 11:58 AM
Cidiverson's Avatar
hi
since i make my a/c fix at acura for 200$ instead of putting the problem here and fix it my self, i cant change the volume or switch song with the volume on the steering i need help
Old Jun 26, 2007 | 12:52 PM
BENDER08's Avatar
Back in a TL again.
do you have an oem raido?
Old Jun 27, 2007 | 07:07 AM
Cidiverson's Avatar
i got the original radio yes i didnt change anything
Old Jun 27, 2007 | 12:41 PM
BENDER08's Avatar
Back in a TL again.
i know before i pulled my oem radio out the volume controls stopped working on my car and later the horn didnt work for me it was the clock spring. the ribbing that runs with the steering wheel. also check the back of the radio maybe the remote wire got unpluggeed
Old Jul 6, 2007 | 11:33 AM
Cidiverson's Avatar
Question
u damn right my horn doesnt work anymore. IT only work when i turn the steering almost complete... what should i do !!????
Old Oct 20, 2007 | 02:01 AM
https://acurazine.com/forums/showthr...highlight=horn
read this thread
Old Oct 20, 2007 | 02:23 AM
philly fresh's Avatar
Its good to be FRESH!!
mine always just messes up. hit the volume up and down button and changes the tracks and the track button does nothing.
Old Oct 20, 2007 | 12:29 PM
BENDER08's Avatar
Back in a TL again.
its the clockspring for a fact i replaced mine just make sure
99-01 and 02-03 are different i have one of a 99 laying around
Old Oct 22, 2007 | 11:46 AM
Cidiverson's Avatar
i got the original radio the one that came with the car. i didnt change nothing
Old Oct 22, 2007 | 11:47 AM
Cidiverson's Avatar
my horn still dont work and i cant change the volume and change the track
Old Oct 22, 2007 | 12:10 PM
fsttyms1's Avatar
Like stated above its the metal ring behind the airbag that makes contact. There was a TSB for it for the dealers. If you feel comfortable removing the airbag and steering wheel (not hard at all) there is a PDF on how to fix it i can send you
Old Nov 10, 2007 | 03:38 PM
GoldAcura03's Avatar
6th Gear
Today my steering volume control went nuts. The down button turns volume up. Up button selects track. Dealer wants $100 for inspection. I disassembled the steering volume control. It seems to generate different resistance for up, down, and track select. Could it be the spring problem listed here? (Radio direct volume knob works fine.) [Gosh! will the cruise control have the same problem!!!]
Old Nov 10, 2007 | 04:04 PM
6th Gear
Hi fsttyms1, could you send me the pdf to disassemble the steering wheel? uscuci@gmail.com
Old Nov 10, 2007 | 04:08 PM
Ron A's Avatar
Administrator
Welcome to the forums.
I deleted your other three posts since they were duplicates of this one and were posted in 1-2 year old threads. This post will be sufficient to get your question answered and whatever assistance may be needed to solve your problems.
Old Nov 10, 2007 | 05:23 PM
6th Gear
Just found out it is not a switch problem. Its in the steering column near 0 degrees (steering straight).
Turn right 90 degrees, switches works fine. Turn left 90 degrees, down button becomes channel select. Turn left 180 degrees, buttons work again.
Old Nov 14, 2007 | 02:15 PM
Hellomoto921's Avatar
Could you send me the PDF too please. Thanks.
Old Nov 16, 2007 | 09:36 AM
fsttyms1's Avatar
http://www.in.honda.com/Rjanisis/pubs/SB/B03-015.PDF
Old Nov 16, 2007 | 01:18 PM
Thank you!!
Feb 25, 2020 09:57 AM
marcelft
Jul 10, 2018 06:17 PM
PortlandRL
Sep 14, 2015 12:01 PM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
