steering rack
Old Jun 8, 2009 | 02:41 PM
joseph_99tl's Avatar
steering rack
has anyone replaced the steering rack?
is there DIY?
Old Jun 8, 2009 | 07:05 PM
fsttyms1's Avatar
Ive never seen a DIY Its not hard, just a little time consuming.
Old Jun 9, 2009 | 08:52 AM
thx, Kris.
i am in the middle of doing the wheel bearings and lower ball joints...and putting back on the OEM exhaust manifold and J pipe and new brakes and shocks and putting back the OEM front springs.
The steering rack is right there...and it's leaking.
i just got a price for a reman rack and 2 new tie rods...260 with core return and 65.00 for 2 moog tie rods.
not a bad price at all.
Old Jun 9, 2009 | 12:40 PM
01tl4tl's Avatar
measure the tie rods and set the new ones the same length- makes it easier to drive to the alignment shop after the work is done
Be sure to tell the alignment guy about all the new parts
rack is just bolts and grease to deal with
see owner book for flushing details DIY- you may want to do a real flush with a bit of seafoam to clean the pump and lines before new rack install, requires a few sets of fill and pump out but well worth it-
keep it all clean inside is my opinion
But then,, I change brake fluid every year
USE HONDA PS FLUID
Old Jun 11, 2009 | 03:58 PM
how do i find and get to the "pinch" bolt that holds the steering column to the input shaft on the steering rack.
man its in a tight place...
do i just push that grommet up until i see the bolt?
also...does anyone know the size of nuts on the power steering lines?
Jul 16, 2017 07:33 AM
spudweb
May 22, 2016 02:39 PM
Euro4gen
Dec 12, 2015 03:14 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
