Steering fluid leak.......helppppp
ok... i'm having bad luck with TL..i bought this car month ago and already pissed...here is new problem.. I checked all fluids in my car and noticed steering fluid was bit low so i bought acura/honda steering fluid and used it..works ok for night but next day i noticed oil on my driveway and after checking i found some oil on the part of the engine bay right underneath the power steering fluid resevior and on top of it ..seems like it was leaking from cap of resevior.. well it I thought may be over fluid and now should be ok..but it'skeep doing it and now it's 10 days almost but keep leaking oil when i drive far (hour or50 km),funny thing is if i look at steering fluid it's still full .. ......help me please .. i like thecar drive nice and smooth..oh yah..I checked fluid because I was feeling steering bit hard..and still do .. compare to my older accord
Originally Posted by bkzjimmy
all i can say is u gotta find where the leak is coming from.....
if u cant....bring it to a local mechanic.
if you fill it to high it will pour out when u turn off the car, check the clamps to see if they are too loose. If they are just get a small clamp to put more pressure on it
start the car and have someone turn the wheel back and forth to get an exact spot. is it the cap? is it 1 of the lines? is the tank cracked?
TL = Tranny Lubrication
06 Anthracite TL
Check to see if the steering fluid is dirty- if it is, and if you are continuously losing fluid with no obvious source involving the reservoir, then the steering rack might be at fault. My wife's car (a Hyundai Elantra), seemed to have a similar problem. I just had it to the dealership (this AM), and I was told the seal in the steering rack is leaking. Ultimately (in this case), the leak would be expected to get worse, and the rack would be replaced as an assembly (it's an $800 repair at Hyundai ).
Just an idea.
Good luck.
Just an idea.
Good luck.
SidhuSaaB
05-30-2020 12:40 AM
acuratl26
04-23-2020 07:30 PM
