SS question
Old Mar 19, 2002 | 07:59 PM
Got_3.2?'s Avatar
Question SS question
hey when i engage the SS should i not accelrate while moving it to SS? kuz when i playing around with it i was going 50 and accelrating when i moved it to SS mode and then i was in 5th gear and when i downshifted the redline flew up. any suggestion on using SS. also will shifting wrong cause damage to my engine? Is it poss to drive with SS on all the time without causing damage??
thanx guys
Old Mar 19, 2002 | 11:03 PM
Bitium's Avatar
Retired MOD
Re: SS question
thanx guys
D5 to SS transition does not have any affect on the engine nor transmission.
You could use SS all the time, neither the engine nor the transmission would give a FK. So no it will not caused any damage other than you the user driving more aggressive.
Old Mar 19, 2002 | 11:52 PM
SL1200MK4's Avatar
well it will cause more tear and ware depends on how you drive...
if you always rev your engine and keep it at 5000+rpm... then of course the egine won't last as long....
but if you are in D5, and you constantly floor the car but release the gas right away (like when you want to pass, but then decided not to) your tranny can be shifting between 5-3-5 or 4-2-4. That can cause extra tear and wear, too...
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
