SRS Warning Light
Old Jan 2, 2008 | 09:41 AM
kgantzer's Avatar
SRS Warning Light
The SRS (Safety Restraint System) warning light came on in my '00 TL last week. Dealer reset the light, and ordered some parts "just in case" the light came back. Three days later, the light came back on. So I now sit at the dealership, and it is being fixed UNDER WARRANTY ! Not sure how much the parts are, but I suspect it is an expensive repair.
The Acura comes with a 10 year safety equipment warranty - good for me !
Additional note: As I sit in the waiting room, I can hear another TL owner call the service desk and complain that the SRS warning light just came on. Sounds like there may be some connection to cold weather and older TLs. Heads up!
Maybe a recall or TSB is on the way.
Old Jan 2, 2008 | 09:44 AM
co1063's Avatar
i reset the light myself and it has not come on ever since.
Old Jan 2, 2008 | 10:22 AM
fsttyms1's Avatar
There is a known issue and a recall and warranty extension has been already been put inplace.
Old Jan 2, 2008 | 10:55 AM
kgantzer's Avatar
Here are the parts that were replaced ...
(2) 91566-SP0-003 Clip, Back Cover
(1) 81334-S0K-307 OPDS Unit
(1) 81127-S0K-A62 Pad, R. FR.
Old Jan 2, 2008 | 11:06 AM
fsttyms1's Avatar
You saved
2.08 each$
182.00$
335.00$
Old Jan 2, 2008 | 11:12 AM
kgantzer's Avatar
You saved
2.08 each$
182.00$
335.00$
Plus labor (approx 1.5 hours).
How does one actually reset this sensor light, anyway ?
Old Jan 2, 2008 | 11:52 AM
gaping46and2's Avatar
SOLD: 03 SSM CLS Auto
http://www.geocities.com/myintegra96/srs.html
Works like a charm.
Old Jan 2, 2008 | 11:57 AM
01tl4tl's Avatar
Acura has a 10 year 150k miles warranty on the SRS system and the parts that were replaced are the ones that fail
You may be able to reset the light if it was an error- BUT beware the Airbags DO NOT WORK when the light is SRS light is on
Get it checked out
Old Jan 2, 2008 | 11:59 AM
01tl4tl's Avatar
Registering your car with acura will provide info on ALL recalls - bulletins and difficulty reports 1-800-382-2238 x5 and tell them you are new owner
and the online version too
https://www.ahm-ownerlink.com/login.asp?brand=acura
you will need your cars VIN for both of those
Old Jan 3, 2008 | 07:51 AM
NSXNEXT's Avatar
Get it checked out
You sure it's 10yr 150K? Mine went off a few months ago and my local dealer said it's not covered.
Oh and it just went off last night. Seems like when I do a panic stop and stuff flies off the front seat it trips the light.
Old Jan 3, 2008 | 11:40 AM
01tl4tl's Avatar
never trust the dealer service writer on the phone
CALL 1 800 382 2238 x5 and ask
Have your VIN handy. I only know about my 01TL and what acura said.
When I registered there- the guy was actually a retired tech who owned an acura and looked things up in 3 different books. He mentioned the SRS and emphasized the importance of it being Light ON means system OFF.
You may also be fooling the system- the passenger seat has a weight sensor- you may notice the side airbag light from time to time when stuff sitting there, if the car thinks your passenger just headed for the dashboard in a panic stop- its NOT going to allow airbags to deploy and should give SRS light to warn you of that
Try storing things properly in back and test drive again
Old Jan 3, 2008 | 08:22 PM
AZP-TL's Avatar
I have this problem as well. Funny thing was the dealer told me it was under warranty and supposedly ordered the parts needed but I never heard back from them and the last time I took it in they tried to weasel out of it. I haven't had much time to take it in to get it fixed.
Old Jan 6, 2008 | 12:42 PM
T4Texas's Avatar
I registered at Owner link but could not find any recall or bulletin information for the SRS light. Can someone point me in the right direction?
Old Jan 6, 2008 | 03:52 PM
01tl4tl's Avatar
Its not listed on the website- thats just basic info
You have to call and register and ask for search of ALL recall and warranty isssues, which I am told are in a physical book not on the computer!
1-800-382-2238 x5
If they say you are covered then get into the dealer!
Old Jan 6, 2008 | 04:42 PM
T4Texas's Avatar
1-800-382-2238 x5
Thanks, I'll give them a cal in the morning....
Old Jul 20, 2010 | 01:23 PM
cemptor's Avatar
I have a 2000 TL with the SRS light on as well. I took it to the local Acura dealer in Northern Virginia, and it turned out I was 4 days after the 10 year extension to the warranty
So he would not fix it under warranty. I even tried calling American Honda and requested them to cover it, but no dice.
So I want to fix it myself. I looked at the Service Bulletin 06-008 (http://ww2.justanswer.com/uploads/ac...01318_opds.pdf) where it describes the procedure for replacing and resetting the OPDS unit.
Need some help figuring our what the "original part number" for the unit is. This will apparently decide whether I need to replace the Seat Back cushion or just the OPDS unit.
The bulletin says:
"Check the part number of the installed OPDS unit.
• If the OPDS unit has an original part number, go to step 6.
• If the OPDS unit has a new part number (refer to PARTS INFORMATION) or higher, go to REPAIR PROCEDURE B: OPDS SENSOR REPLACEMENT."
The new part # as listed in the bulletin (and I have it) is 81334-S0K-307, and the old part number in the Acura is 81334-S0K-A612-M1 . How do I know if that is the "original" or not? Googling hasn't helped.
Do I need to replace both the seat back cover and the OPDS unit, as was done for a poster on another thread?
mada51589
Jan 9, 2025 04:40 PM
mugen_kid
Nov 13, 2015 10:38 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
Rob144
Sep 21, 2015 08:18 AM
