SRS light on
Old 09-01-2010, 07:58 PM
  #41
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
had the codes read for free at parts store yet?
Old 09-01-2010, 08:17 PM
  #42
4th Gear
acura4jr's Avatar
Gonna hit AAP tomorrow and scan it, then I'll do the rest by shorting at the MES connector. Then, I'll call the SERVICE MGR if it comes back again (you are so right about that point, techs are by the book guys)
Only thing I've done is replace the starter motor about 6 weeks ago, other than that, oil changes and that's pretty much it. Battery is a little low on the CCA #, and today was 100 degrees and wicked humid. Wondering if system threw code that inidcates SRS couldn't charge properly due to low amps/voltage (I think I had this happens years ago, was time to replace battery).
Not convinced it is battery just yet, it is about 3 years on a 4 year autozone battery.
Old 09-03-2010, 01:42 AM
  #43
meraj's Avatar
well not that i recommend it but how about opening up your dash and black electric tape on the SRS light?
Quick and cost effective
Old 09-03-2010, 10:25 AM
  #44
01tl4tl's Avatar
get the battery tested at parts stores before proceeding with diagnosis- you may be right on with the low voltage
any battery lasting 3-4 years in a TL is doing good for you!! (optimas last longer)
TIP: drive 30-45 minutes on freeway before test so battery is as full as alt will get it.
Then it can be safely load tested- simulating a max load surge,(lights/ac stereo all on while at idle) and watching its abilty to recover from that
the reason NOT to tape over the light is
A: you have NO airbags when light on
B: usa cars have a 10 year 150,000mile SRS warranty--
as ordered by the court no doubt--we score on those cases!!
mada51589
05-03-2022 08:54 PM
12-07-2020 05:39 PM
mugen_kid
11-13-2015 10:38 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
Quick Reply: SRS light on
