SRS light
SRS light
I have 1999 tl and...
my SRS light came on the other day...
i checked the fuse...it's ok....
anybody know what i should check next?
is there another fuse i need to check?
i have a vtec controller and cai installed..
so i kinda want to avoid going to the dealer just for a light...
BlingBling INSPIRE 32V
Have dealer check it for you....
It's not just a light......it's problem with SRS system.... I am sure it can be cover under warranty (not sure what your milage is though)
Guest
Posts: n/a
I would highly rec. you go to the dealer.There is no easy way to reset this system or diagnose it's problems without specific info about it.Pulling fuses will not clear the memory as it is nonvolatile and will remeber till told to forget even if you disconnect the battery.
The most likely source of trouble on these early cars will be the safety belt latch.This will probably be covered since Acura offers lifetime warranty on all safety belts.It is unlikely that the installation of your vtec controller will have an effect on the srs system sincew none of the wiring you need for that are part of the srs system.
Jens
Jens
mada51589
05-03-2022 08:54 PM
mugen_kid
11-13-2015 10:38 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
