squeeky belt
Old 01-02-2004 | 11:16 AM
badazzTL's Avatar
Peach Tea
squeeky belt
hi, i think my timing belt is squeeking. what can i do? my warranty ends this month:o
i have an 00 with 40K miles.
Old 01-02-2004 | 11:58 AM
njtls's Avatar
its not part of the recall?
Old 01-02-2004 | 02:22 PM
badazzTL's Avatar
Peach Tea
im not sure, is there a place i can check recalls? thanks
Old 01-02-2004 | 06:49 PM
TL260power's Avatar
when i check the history report for a car through carfax they have a section for recalls. ive checked for honda you can try this number and see if they have the number for acura.
1-800-999-1009
im sure they can tell you the acura number or maybe they can help you. First ask them since you have an acura can they still help you knowing your car is still honda. im sure they can. ask them if your acura still has recalls that require repair. see what happens
good luck let me know what happen
Old 01-02-2004 | 06:59 PM
fsttyms1's Avatar
are you sure its not one of your other belts? they are all on the same side of the engine. i kinda doubt it is the timing belt.
Old 01-02-2004 | 10:26 PM
larryr20's Avatar
you can tell if it is one of the other belts by running the engine and spraying a little water on them. If it gets quiet, then it is one of the outside belts. The timing belt is enclosed (im tending to think its not this)
Old 01-02-2004 | 10:41 PM
medic's Avatar
there is belt dressing you can spray on them to quiet them
before doing that though check to make sure they aren't cracked or need to be replaced...40k is pretty low, but u never know
08KBP_VA
10-22-2019 01:55 PM
brboy
10-05-2015 11:34 AM
Jboat
09-30-2015 10:58 AM
Boraxo
1/2G MDX (2001-2013)
09-29-2015 04:35 PM
Quick Reply: squeeky belt
