squeeking noise when releasing brakes
More info here????
does it do it while moving?
does it do it when sitting still?
could it be your break pedal?
Dragging knees in
Originally Posted by 1st timer
do your brakes make a squeeking sound when you release the pedal slowly?
Does this happen when it's in park and/or drive? In other words, if you let go of the brakes slowly while in drive, and the car starts moving and makes a squeaking sound, then it's probably your pads.
But if this happens while in park, as in the car is not moving at all, but still makes a sound as you release the brake pedal, then it's your brake booster. It's got a leak.
